Hi all,
I am new to working with Arduinos. I appreciate any help.
I purcahsed an Arduino Leonardo from Digikeys. Along with this I also got the ATMEGA328-pu chip - which apparently does not come with the bootloader installed. I’ve looked at several tutorials on how to hook up the Leonoardo to act as the ISP (“Arduino as ISP” setting). But I am having some trouble.
Here is my software/hardware details:
- I am using a mac with version 10.11.6
- I am using the Arduino software version 1.8.5
Here is what I have done so far:
Successfully loaded the sketch “ArdunioISP”. I did not do any modifications to this sketch.
Connected the following:
- Pin 10 on Leonardo to Pin 1 on ATMEGA (Reset)
- Pin 11 on Leonardo to Pin 17 on ATMEGA (MOSI)
- Pin 12 on Leonardo to Pin 18 on ATMEGA (MISO)
- Pin 13 on Leonardo to Pin 19 on ATMEGA (SCK)
- 5V and ground respectively. - I have a 1 k Ohm resistor between Pin 1 and 5V on the ATMEGA. Also have a pushdown button connected to the ground at act as the reset.
- I’ve connected an 16 MHz clock between pins 9 and 10 on the ATMEGA, with two 104 caps going to ground.
- I’ve connected Pins 7, 20 and 21 on the ATMEGA to 5 V. And Pins 8 and 21 on the ATMEGA to ground.
Set programmer to “Arduino as ISP”
Verified that my board is still set to “Arduino Leonardo” and that I have the proper port selected
Burn Bootloader is where it fails. The following is the output I get:
Arduino: 1.8.5 (Mac OS X), Board: “Arduino Leonardo”
/Users/MathPi/Desktop/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Users/MathPi/Desktop/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega32u4 -cstk500v1 -P/dev/cu.usbmodem1461 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xcb:m -Uhfuse:w:0xd8:m -Ulfuse:w:0xff:m
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:01:35
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is “/Users/MathPi/Desktop/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf”
User configuration file is “/Users/MathPi/.avrduderc”
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodem1461
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 9000 9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x000000 (retrying)
Error while burning bootloader.
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.
Any thoughts on what I set up incorrectly? Thanks in advance.
Cheers,
MathPi
