good afternoon. For experimental purposes, I would like to use the main() function in the sketch and not setup() and loop()
That's OK - you don't have to ask permission.
Then you will not automatically have access to the Arduino libraries, but you must know this.
Might be better not reinventing the wheel.
Something like this should work.
int main() {
init();
// Setup code here.
while (true) {
// Loop code here.
You may have to add a call to initVariant() for board specific initialisations.
It he still compiles using the IDE, of course he will. I've done it many times.
Yes, same here.
