Using Map() multiple times on same input/output
Hello there, first post so hoping this is the correct place!
I am trying to make a RGB LED light up and down with a potentiometer. What I want is to use the map function (or any other way to make it happen), to make it light up from 0-512, then dim it down between 513-1023.
So far, this is the relevant part of my code:
 int potPositionR1;
void loop()  {
  int potPositionR1 = analogRead(A0);
  potPositionR1 = map(potPositionR1, 0, 512, 0, 255);
  potPositionR1 = map(potPositionR1, 513, 1023, 255, 0);
  analogWrite(9, potPositionR1);
delay(50);
Interestingly enough, this code makes it dim down as if I had it mapped (0, 1023, 255, 0)...
Is there any way for me to make it work so that I can map the same output and input to different things at different values from the potentiometer?
How about…
if (potPositionR1 <= 512) {
quarrry:
something like this maybe…
(compiles, NOT tested):
int potPositionR1;
  //nothing here for now...
void loop()  {
  if (potPositionR1 < 513) {
    //light up
  else {
    //dim
  delay(50);
hope that helps…
PS: @pcbbc beat me to it! :stuck_out_tongue:
Thank you both, pcbbc and sherzaad! It worked just how I wanted it to!
I had messed around with if else statements earlier today but this is my first week of arduino and I couldn't make it work (also no help googling like a madman). Had not thought about putting the mapping into the if else statements themselves :slight_smile:
Mapping between two ranges where both start or end at 0 can be done with a simple multiply or divide.
For example, 0…1023 → 0…255 is equivalent to dividing by 4.
  if (potPositionR1 < 512)
    potPositionR1 /= 2;  // 0..511 -> 0..255
    potPositionR1 = (1023 - potPositionR1) / 2;  // 512..1023 -> 511..0 -> 255..0
What colors do you want the different position of the pot to map to?
-jim lee
