So my goal here is to pretty much specifically use mat lab so that I can read audio signals from a 3.5mm jack. This will go to my arduino, then Matlab will control the data. Once my audio wave is separated into 100 Hz, 400 Hz, 3kHz, and 10 kHz, I want to display this on a small LED array. I'm pretty new to this so I appreciate any information I can get. The less I can use the C programming interface the better. I'm okay with the project only working while being connected to a computer.
in I'm not sure if this is the correct forum but I figured it should be.
