Hi guys
Essentially what I've done so far is use a light sensor to make a pizeo buzzer make beeping noises depending on the level of light. When there is less light, it beeps faster, and when there is more light, is beeps slower.
In addition, I've put in a an LED and it flashes with the pizeo buzzer beeps.
Essentially they both use the the sensorValue time to do their thing.
My question is how i can incorporate mills() into it rather than using the delay. Me using the delay means the LED flash and buzzer don't quite line up.
I have done the mills example within the program but i don't really know how i can apply it in this situation.
The code is
Light sensor, Piezo and LED project
int piezoPin = 8; // Declaring Piezo Buzzer on Pin 8
int lightsensorPin = 0; // Declaring light sensor on Analog Pin 0
int sensorValue = 0; // Reading different values from the sensor
int ledPin = 3; // PWM pin
//long int previousMillis =0;
//const long interval = 25;
pinMode(lightsensorPin, INPUT);
pinMode(ledPin, OUTPUT);
{// Starting the cycle functions below
sensorValue = analogRead(lightsensorPin); // read the value from the light sensor
tone(piezoPin, 500); // Play a 1000Hz tone from the piezo (beep)
delay(30); // wait a bit, change the delay for fast response.
noTone(piezoPin); // stop the tone
delay(sensorValue); // wait the amount of milliseconds (sensorValue is a number);
digitalWrite(ledPin,HIGH);
delay(sensorValue);
digitalWrite(ledPin,LOW);
delay(sensorValue);
Thanks in advance
