Does anyone have a simple schematic of how to connect the MQ-2 to an MKR1010. I understand there is a 5v/3.5v issue, and that a resistor may solve the problem, but what value of resistor, and where to place it in the circuit?
Would really appreciate a schematic . . . thank you in advance.
For that sensor, you will need USB 5V or a regulated 5V power supply for the heater, and to interface with the ADC on the MKR1010, a voltage divider to reduce the output voltage. Example:
