Hi everyone!
I'm really new with internet protocols so sorry if this might be a stupid question, but my final goal would be to send some data into a server. Until now I was using TCP/IP commands to do so, with an SIM868. SInce 2G is not available anymore in my country, I decided to use the SIM 7600E-H module with MQTT protocol. The problem is, I am not able to establish MQTT Connection with the command AT+CMQTTSTART. I always get this error:
+CMQTTSTART: 23
ERROR
On the AT commands datasheet (https://simcom.ee/documents/SIM7600E/SIM7500_SIM7600%20Series_MQTT_ATC_V1.01.pdf ) of the module, it's written that it means that "network is opened". The problem is, I don't know what that means and I can't find more information.
When using the AT command AT+CNSMOD, I get a response saying that the current network system is LTE, so I guess that it's not a problem of bad signal/internet connection.
Has anyone been using this module with 4G? Is there any already existing library for this module?
Thank you for your help! ![]()
