Using multiple modules with Arduino
Hello,
I am working on a project where i use and arduino uno(drfduino uno, i understand that is very similar) integrated with 2 modules(one is GSM --SIM800l-- and the one is GPS --GY-NEO6MV2--.
If i use them separately they are working but when they are all put together in a code, i cant listen to to the ports(software serial). I am testing the code inside so the GPS wouldnt work anyway but when i put the ss.listen() in the void loop(); the SIM800l.listen(); isnt working neither. Can you guys give me and advice pls.
#include <SoftwareSerial.h> //Software Serial header to communicate with GSM module
#include <TinyGPS++.h>
static const int RXPin = 4, TXPin = 3;
static const uint32_t GPSBaud = 9600;
// The TinyGPS++ object
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial SIM800(11, 10); // RX, TX
SoftwareSerial ss(RXPin, TXPin);
String Link = "The current Location is https://www.google.com/maps/place/"; //we will append the Lattitude and longitude value later int the program
String responce = "";
String Longitude = "";
String Latitude = "";
String Date ="";
String Time ="";
String result2 = "";
String SIM800_send(String incoming) //Function to communicate with SIM800 module
    SIM800.println(incoming); delay(100); //Print what is being sent to GSM module
    String result = "";
    while (SIM800.available()) //Wait for result
    char letter = SIM800.read();
    result = result + String(letter); //combine char to string to get result
return result; //return the result
//PWRKY pin of GSM module has to be pulled low for 1sec to enable the module
  Serial.begin(9600); //Serial COM for debugging
  ss.begin(9600);
  SIM800.begin(9600); //Software serial called SIM800 to speak with SIM800 Module
  delay(1000); //wait for serial COM to get ready
  responce = SIM800_send("ATE1"); //Enable Echo if not enabled by default
  Serial.print ("Responce:"); Serial.println(responce);
  responce = SIM800_send("AT+CGATT=1"); //Set the SIM800 in GPRS mode
  responce = SIM800_send("AT+SAPBR=3,1,\"CONTYPE\",\"GPRS\" "); //Activate Bearer profile
  responce = SIM800_send("AT+SAPBR=3,1,\"APN\",\"net\""); //Set VPN options => 'RCMNET' 'www'
  delay(2000);
  responce = SIM800_send("AT+SAPBR=1,1"); //Open bearer Profile
  Serial.print ("Responce:"); Serial.println(responce); //Open bearer Profile
  delay(2000);
  responce = SIM800_send("AT+SAPBR=2,1"); //Get the IP address of the bearer profile
void prepare_message()
  //Sample Output for AT+CLBS=1,1   ==> +CIPGSMLOC: 75.802460,26.848892,550 //where 26.8488832 is Lattitude and 75.802460 is longitute
  int first_comma = responce.indexOf(','); //Find the position of 1st comma
  int second_comma = responce.indexOf(',', first_comma+1); //Find the position of 2nd comma
  int third_comma = responce.indexOf(',', second_comma+1); //Find the position of 3rd comma
  for(int i=first_comma+1; i<second_comma; i++) //Values form 1st comma to 2nd comma is Longitude
    Longitude = Longitude + responce.charAt(i);
  for(int i=second_comma+1; i<third_comma; i++) //Values form 2nd comma to 3rd comma is Latitude
    Latitude = Latitude + responce.charAt(i);
  Serial.println(Latitude); Serial.println(Longitude);
  Link = Link + Latitude + "," + Longitude; //Update the Link with latitude and Logitude values
  Serial.println(Link);
String incoming = "";
  ss.listen();
  while (ss.available() > 0)
    gps.encode(ss.read());
    if (gps.location.isUpdated())
      // Latitude in degrees (double)
      Serial.print("Latitude= ");
      Serial.print(gps.location.lat(), 6);
      Latitude = gps.location.lat();
      // Longitude in degrees (double)
      Serial.print(" Longitude= ");
      Longitude = gps.location.lng();
      Serial.println(gps.location.lng(), 6);
      // Raw latitude in whole degrees
      Serial.print("Raw latitude = ");
      Serial.print(gps.location.rawLat().negative ? "-" : "+");
      Serial.println(gps.location.rawLat().deg);
      // ... and billionths (u16/u32)
      Serial.println(gps.location.rawLat().billionths);
      // Raw longitude in whole degrees
      Serial.print("Raw longitude = ");
      Serial.print(gps.location.rawLng().negative ? "-" : "+");
      Serial.println(gps.location.rawLng().deg);
      Serial.println(gps.location.rawLng().billionths);
      // Raw date in DDMMYY format (u32)
      Serial.print("Raw date DDMMYY = ");
      Serial.println(gps.date.value());
      Date = gps.date.value();
      // Year (2000+) (u16)
      Serial.print("Year = ");
      Serial.println(gps.date.year());
      // Month (1-12) (u8)
      Serial.print("Month = ");
      Serial.println(gps.date.month());
      // Day (1-31) (u8)
      Serial.print("Day = ");
      Serial.println(gps.date.day());
      // Raw time in HHMMSSCC format (u32)
      Serial.print("Raw time in HHMMSSCC = ");
      Serial.println(gps.time.value());
      Time = gps.time.value();
      // Hour (0-23) (u8)
      Serial.print("Hour = ");
      Serial.println(gps.time.hour());
      // Minute (0-59) (u8)
      Serial.print("Minute = ");
      Serial.println(gps.time.minute());
      // Second (0-59) (u8)
      Serial.print("Second = ");
      Serial.println(gps.time.second());
      // 100ths of a second (0-99) (u8)
      Serial.print("Centisecond = ");
      Serial.println(gps.time.centisecond());
  SIM800.listen();
  if (SIM800.available())
  { //Check if the SIM800 Module is telling anything
    char a = SIM800.read();
    Serial.write(a); //print what the module tells on serial monitor
    incoming = incoming + String(a);
    if (a == 13) //check for new line
    incoming =""; //clear the string if new line is detected
    incoming.trim(); //Remove /n or /r from the incomind data
    if (incoming=="RING") //If an incoming call is detected the SIM800 module will say "RING" check for it
     Serial.println ("Sending sms"); delay(1000);
     responce = SIM800_send("ATH"); //Hand up the incoming call using ATH
     delay (1000);
     responce = SIM800_send("ATE0"); //Disable Echo
     delay (1000);
     responce = "";
     if ( (Latitude=="") && (Longitude=="") )
      SIM800.println("AT+CLBS=1,1"); delay(5000); //Request for location data
       responce = responce + String(letter); //Store the location information in string responce
      Serial.print("Result Obtained as:");   Serial.print(responce); Serial.println("*******");
      prepare_message(); delay(1000); //use prepare_message funtion to prepare the link with the obtained LAT and LONG co-ordinates
     SIM800.println("AT+CMGF=1"); //Set the module in SMS mode
     SIM800.println("AT+CMGS=\"+40753159104\""); //Send SMS to this number
     SIM800.println(Link); // we have send the string in variable Link
     SIM800.println((char)26);// ASCII code of CTRL+Z - used to terminate the text message
  if (Serial.available())
  { //For debugging
    SIM800.write(Serial.read());
Welcome to the forum!
Thank you for posting the code, but, could you please place all of it within the CODE tags? As presented, it is very difficult to read as the formatting is lost.
Trying to use two software serial instances is not easy.
Better to use an Arduino with enough hardware serial ports.
Arduino MEGA should work?
I changed it, sorry
Well it has 3 more hardware serial ports over a UNO.
If I use one module for the hardware serial and 1 for software serial should work?
If i am using an arduino mega, the thing i should change in the code is to remove software serial and instead of ss. and SIM800l. i use Serial. and Serial1. ?
Easier to use Serial1 andf Serial2.
I tried to use this, it seems to be working, i mean the GSM is working. I changed the GPS pins, how should i put the pins TX from GPS to RX to arduino and Rx from GPS to Tx to arduino?
Thank you. Your code is now much easier to read.
Not quite sure what question you are asking here? Have you switched to using a Mega 2560 board as per srnet's suggestion? If so, then on this board, pins 14,15 will be the pins for Serial 3, pins 16,17 for Serial 2 and pins 18,19 will be for Serial 3. It should be printed on the PCB.
No, i tried to use with arduino uno the hardware serial(i switched the pins for GPS) and the software serial at the same time. It seems to be working in the Serial Monitor but i have this error
Arduino: 1.8.10 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 15254 bytes (47%) of program storage space. Maximum is 32256 bytes.
Global variables use 1458 bytes (71%) of dynamic memory, leaving 590 bytes for local variables. Maximum is 2048 bytes.
An error occurred while uploading the sketch
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
option enabled in File -> Preferences.
Yeah, i tried this code, the sim800l seems to be working but it shows a bunch of bullshit from the GPS, he s supposed to not be working because im inside the building
TinyGPSPlus gps;
String Date ="";
String Time ="";
    String result = "";
  delay(2000);
  delay(2000);
  while (Serial.available() > 0)
    gps.encode(Serial.read());
      // Day (1-31) (u8)
      // Hour (0-23) (u8)
  SIM800.listen();
     delay (1000);
     delay (1000);
     responce = "";
  { //For debugging
Pins 0 and 1 are also used for communication with the PC. Connecting something to them will interfere with the upload.
So disconnect before upload and reconnect again afterwards.
Yeah, still didnt work, i think i should buy an arduino mega.
