Below is the code..
I just deleted some parts in the loop section (which were for controlling components by the Arduino) as the forum has character limit.
// section of the operateMainMenu() function below.
String menuItems[] = {"Time", "Sampling Time"};
// Navigation button variables
int readKey;
int savedDistance = 0;
// Menu control variables
int menuPage = 0;
int maxMenuPages = round(((sizeof(menuItems) / sizeof(String)) / 2) + .5);
int cursorPosition = 0;
// Creates 3 custom characters for the menu display
byte downArrow[8] = {
byte upArrow[8] = {
byte menuCursor[8] = {
// ***** Main Code **
#include <Wire.h>
#include <LiquidCrystal.h>
extern "C" {
#include "utility/twi.h" // from Wire library, so we can do bus scanning
#include "DFRobot_SHT20.h"
DFRobot_SHT20 sht20;
#define TCAADDR 0x70
void tcaselect (uint8_t i) {
if (i > 7) return;
Wire.beginTransmission(TCAADDR);
Wire.write(1 << i);
Wire.endTransmission();
//Variables and setpoints
int chk;
float HUM; //Stores humidity value
float Temp; //Stores temperature value
#define HiTEMP 24.85
#define LoTEMP 24.2
#define Compen 0.2 // the temperature defference which is supposed to be Compensated by heating pad
#define HumSETPOINT 50 // These values are based on trial and error for acheiving the best humidity conditions
#define HumRESOLUTION 0.5
// A 1602 SainSmart LCD Keypad module has been used in this setup
LiquidCrystal lcd (8, 9, 4, 5, 6, 7); // Initialize the library with the numbers of the interface pins
// Units SETUP *************************************************
int fan = 1; // The pin number that fan is connected to
int HumFan = 13;
int HumFanSpeed = 22;
int SolHum = 2;
int SolMain = 3;
int SolEx =11;
int WB = 53;
int Hpad = 52;
#define HUMIDIFIER 12 //setting humidifier to pin 12
#define ON false //turns ON the Relay Board Contact
#define OFF true //turn OFF the Relay Board Contact
#define SensorHum 40 //For the water level switch in the humidifier
#define SensorMain 42 //For the water level switch in the main chamber
#define SensorEx 44 //For the water level switch in external water bath
//*********************** LCD Initials ************************
// define some values used by the panel and buttons
int lcd_key = 0;
int adc_key_in = 0;
#define btnRIGHT 0
#define btnUP 1
#define btnDOWN 2
#define btnLEFT 3
#define btnSELECT 4
#define btnNONE 5
// read the buttons
int read_LCD_buttons()
adc_key_in = analogRead(0); // read the value from the sensor
// my buttons when read are centered at these valies: 0, 144, 329, 504, 741
// we add approx 50 to those values and check to see if we are close
if (adc_key_in > 1000) return btnNONE; // We make this the 1st option for speed reasons since it will be the most likely result
// For V1.1 us this threshold
if (adc_key_in < 50) return btnRIGHT;
if (adc_key_in < 250) return btnUP;
if (adc_key_in < 450) return btnDOWN;
if (adc_key_in < 650) return btnLEFT;
if (adc_key_in < 850) return btnSELECT;
return btnNONE; // when all others fail, return this...
#define MILLIS_OVERFLOW 34359738
// To control solenoid valve a time control is required
// ********* Clock Variables ***
unsigned long currentMillis, previousMillis, elapsedMillis;
int seconds, minutes, hours;
boolean start= true;
boolean a = false;
Wire.begin(); //Initialize I2C Harware
//INITIALIZING SENSORs
tcaselect(4);
sht20.initSHT20();
Serial.println("SHT20 Blue!");
sht20.checkSHT20();
tcaselect(6);
sht20.initSHT20();
Serial.println("SHT20 Green!");
sht20.checkSHT20();
tcaselect(7);
sht20.initSHT20();
Serial.println("SHT20 Yellow!");
sht20.checkSHT20();
pinMode(fan, OUTPUT);
pinMode(HUMIDIFIER, OUTPUT);
digitalWrite(HUMIDIFIER, OFF);
pinMode(HumFan, OUTPUT);
digitalWrite(HumFan, OFF);
pinMode(SolMain, OUTPUT);
pinMode(SolHum, OUTPUT);
pinMode(SolEx, OUTPUT);
pinMode(WB, OUTPUT);
digitalWrite(WB, OFF);
pinMode(Hpad, OUTPUT);
digitalWrite(Hpad, OFF);
lcd.begin(16, 2);
lcd.clear();
//FAN Initialization ****
analogWrite(fan, 255); // Fan needs to work very slowly and this is just to initialize the fan
analogWrite(fan, 25);
lcd.print("Hello..");
digitalWrite(SolMain, OFF); // After reseting the setup each time Select Bottun should be pressed to reset the time for Solenoid Valve Control
digitalWrite(SolHum, OFF);
digitalWrite(SolEx, OFF);
if (lcd_key == btnSELECT || start == false ) {
setClock();
start = false;
//READING Humidity and Temperature*******
//There are 3 SHT20 sensors connected to channels # 4,6 and 7 of the multiplexer
//Channel #5 is connected to a SHT10 which is left idle as it does seem to be compatible with i2c bus connections
lcd.setCursor(0, 1); // set the cursor to column 0, line 1
for (int i=1;i<5;i++){
if(i=2){return; //skiping sht10 for now
tcaselect(i+3);
Temp =+ sht20.readTemperature();
HUM =+ sht20.readHumidity();
delay(100);
float hum = HUM/3;
float temp = temp/3;
//Controlling Humidity *********
//deleted
// Controlling Water Bath
//deleted
// Controlling Heating Pad
//deleted
// LCD Display and Menu
lcd_key = read_LCD_buttons(); // read the buttons
switch (lcd_key) // depending on which button was pushed, we perform an action
case btnRIGHT:
mainMenuDraw();
drawCursor();
lcd.setCursor(0, 0);
lcd.print("Elapsed Time:");
lcd.setCursor(7,1);
lcd.print(hours);
lcd.print(":");
lcd.print(minutes);
lcd.print(":");
lcd.print(seconds);
case btnLEFT:
mainMenuDraw();
drawCursor();
lcd.print("Fan Speed:");
lcd.setCursor(7,1);
case btnSELECT:
mainMenuDraw();
drawCursor();
if (lcd_key == btnSELECT && start == false) {
lcd.setCursor(0,0);
lcd.print("TEST Running !");
else {
lcd.setCursor(0,0);
lcd.print("TEST STARTED!");
delay(2500);
a = true;
case btnUP:
mainMenuDraw();
drawCursor();
if (a == true){
lcd.print("Next Sampling:");
lcd.setCursor(7,1);
lcd.print(59 - minutes);
lcd.print(":");
lcd.print(59 - seconds);
else{
lcd.print("TEST Has Not ");
lcd.print("Been Started Yet!");
case btnNONE:
mainMenuDraw();
drawCursor();
lcd.setCursor(0,0);
lcd.print("Temp: ");
lcd.setCursor(0,1);
lcd.print("Humidity: ");
lcd.setCursor(10,0);
lcd.print(temp,1);
lcd.setCursor(14,0);
lcd.print("C");
lcd.setCursor(10,1);
lcd.print(hum,1);
lcd.setCursor(14,1);
lcd.print("%");
if (a == true){
lcd.setCursor(15,1);
lcd.print((char)126);
Serial.print(hours);
Serial.print(":");
Serial.print(minutes);
Serial.print(":");
Serial.print(seconds);
Serial.print(",");
Serial.print(hum);
Serial.print(",");
Serial.println(temp);
if (minutes == 0 && seconds == 0 )
/Solenoid Valves Control****/
//deleted
// ********** Menu FUNCTIONS *******************
// This function will generate the 2 menu items that can fit on the screen. They will change as you scroll through your menu. Up and down arrows will indicate your current menu position.
void mainMenuDraw() {
Serial.print(menuPage);
lcd.clear();
lcd.setCursor(1, 0);
lcd.print(menuItems[menuPage]);
lcd.setCursor(1, 1);
// lcd.print(menuItems[menuPage + 1]);
if (menuPage == 0) {
// lcd.setCursor(15, 1);
// lcd.write(byte(2));
} else if (menuPage > 0 and menuPage < maxMenuPages) {
lcd.write(byte(2));
lcd.setCursor(15, 0);
lcd.write(byte(1));
} else if (menuPage == maxMenuPages) {
lcd.write(byte(1));
// When called, this function will erase the current cursor and redraw it based on the cursorPosition and menuPage variables.
void drawCursor() {
for (int x = 0; x < 2; x++) { // Erases current cursor
lcd.setCursor(0, x);
lcd.print(" ");
void setClock()
currentMillis = millis();
if (currentMillis < previousMillis){
elapsedMillis += MILLIS_OVERFLOW - previousMillis + currentMillis;
elapsedMillis += currentMillis - previousMillis;
if (elapsedMillis > 999){
seconds++;
elapsedMillis = elapsedMillis - 1000;
if (seconds == 60){
minutes++;
seconds = 0;
if (minutes == 60){
hours++;
minutes = 0;
if (hours == 24){
hours = 0;
