The SAM D21 pins 19, 20, 21 and 22 are not connected to the pin headers, but I want to use them as digital I/O pins D14, D15, D16, D17, just as D0, D1 etc. How can I do this?
These pins constitute the SPI port on the Zero's 6 pin header, with the exception of pin 22 which is the ATN pin, (on pin header next to the IOREF). (Note: The M0/M0 Pro omits the ATN pin).
The pins are named as follows:
Pin 19 - MOSI
Pin 20 - SCK
Pin 21 - MISO
Pin 22 - ATN
For example to write a logic HIGH to the MOSI pin:
pinMode(MOSI, OUTPUT); // Set the MOSI pin to an output
digitalWrite(MOSI, HIGH); // Set the MOSI pin HIGH
MartinL:
These pins constitute the SPI port on the Zero's 6 pin header, with the exception of pin 22 which is the ATN pin, (on pin header next to the IOREF). (Note: The M0/M0 Pro omits the ATN pin).The pins are named as follows:
Pin 19 - MOSI
Pin 20 - SCK
Pin 21 - MISO
Pin 22 - ATNFor example to write a logic HIGH to the MOSI pin:
Thanks very much.
