Using POST and WIFININA on Uno Wifi Rev2
The following library can be installed using the IDE Library manager and includes a simple POST example. I tried the example with a MKR1010/WiFiNINA and it works. It should work on other boards using the WiFiNINA library (and maybe Adafruit's airlift fork).
The simple POST example modified to work with a public HTTP test server named httpbin.org.
  Simple POST client for ArduinoHttpClient library
  Connects to server once every 30 seconds, sends a POST request
  and a request body
  created 14 Feb 2016
  modified 22 Jan 2019
  by Tom Igoe
  this example is in the public domain
  Modified to work against httpbin.org. The equivalent POST using curl is:
  curl --data "arg1=value1&arg2=value2" --verbose http://httpbin.org/post
  The response body contains JSON showing the values and headers received by the httpbin
  server. Example follows.
making POST request
Status code: 200
Response: {
  "args": {},
  "data": "",
  "files": {},
  "form": {
    "arg1": "value1",
    "arg2": "value2"
  "headers": {
    "Content-Length": "23",
    "Content-Type": "application/x-www-form-urlencoded",
    "Host": "httpbin.org",
    "User-Agent": "Arduino/2.2.0"
  "json": null,
  "url": "https://httpbin.org/post"
#include <ArduinoHttpClient.h>
#include <WiFiNINA.h>
#include "arduino_secrets.h"
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
/////// Wifi Settings ///////
char ssid[] = SECRET_SSID;
char pass[] = SECRET_PASS;
const char serverName[] = "httpbin.org";  // server name
int port = 80;
WiFiClient wifi;
HttpClient client = HttpClient(wifi, serverName, port);
int status = WL_IDLE_STATUS;
  while ( status != WL_CONNECTED) {
    Serial.print("Attempting to connect to Network named: ");
    Serial.println(ssid);                   // print the network name (SSID);
    // Connect to WPA/WPA2 network:
    status = WiFi.begin(ssid, pass);
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your WiFi shield's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  Serial.println("making POST request");
  String contentType = "application/x-www-form-urlencoded";
  String postData = "arg1=value1&arg2=value2";
  client.post("/post", contentType, postData);
  // read the status code and body of the response
  int statusCode = client.responseStatusCode();
  Serial.print("Status code: ");
  Serial.println(statusCode);
  String response = client.responseBody();
  Serial.print("Response: ");
  Serial.println(response);
  Serial.println("Wait 30 seconds");
  delay(30000);
