I've been messing with a 12v computer fan recently and need to control it's speed.
I'm currently using PWM from the Arduino with a transistor to gate the 12v line. It's working fine, but when I'm not in 100% duty cycle (sending 255 through the PWM port), the fan start to produce a high pitched noise, that gets higher as I slow down the fan. Why am I hearing that noise and should I be worried about it? Is it because I'm using PWM instead of a regulated voltage?
It would help if we had some idea which fan you were controlling (whether it is meant to be PWM'ed for instance), which transistor you are using (is it capable of switching as fast as the Arduino switches), and how the transistor, fan, and Arduino are wired.
If it is a PWM fan, you'll need to change the Arduino's PWM frequency: Very few fans are built to accept a ~500Hz PWM signal. The standard for PC PWM fans is 25kHz! ~30khz works fine too, and the Arduino can put that out.
If it is a non-PWM fan, that's a different setup altogether.
Many fans work by generating there own PWM current pulses. By giving it an external PWM you are in effect chopping of the voltage when it needs it. The result is that the two frequencies beat with one another to produce the noise you here.
Should you be worried about it? It depends on your application. The fan will not last as long in this mode but it is hard to say by how much.
The fan is a cheap 12V DC computer case fan, like this one:
I've used PWM because I couldn't think of a cheap & easy way to output a controlled voltage varying from 0 to 12V using the Arduino, so I'm running a 12V line where the fan and the transistor are wired and I'm connecting pin 11 of the Arduino to the gate of the transistor, so I can have a 12V PWM signal. Here's the basic circuit:
PaulS:
Let's go back to the beginning. Why do you want to control the speed of the fan using PWM? What is the fan doing that requires varying the speed?
I don't want to control the fan speed using PWM, I want to control the fan speed (PWM was simply the easiest way I found to do it).
This is my prototype:
You can't hear the high pitched noise that I mentioned because I've added a piece of paper into it for demonstration purposes, as it would be hard to see the fan speed changing.
That it should do, the most common computer fan controllers out there are simple resistors to act as a voltage drop, the vast majority of fans will run till at least 7v, most will run till 5v if already turning. Starting takes more voltage though.
The low pass filter has to be able to smooth the voltage for a draw somewhere between .1 and 4 amps depending on the fan, if it's on the chunkier end of things that can be an issue.
