I'm using RTC 1307 and OLED on a Arduino MEGA together.
When I try to set the time with
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
in the void.setup() then upload the code,i cannot see at OLED display what I wrote in "void loop()". On OLED display i wish something else than time.now() or etc. Just another variables.
I thought that it might be about I2C issue and set Serial.begin() with different bautrates. It didnot help.
Since the code is very long to share, i shared the logic of the problem
I didnot gave the whole code since this part seems enough for solving the problem. Because when I uncomment the following part, the code works:
Serial1.begin(57600);
if (! rtc.isrunning()) {
Serial1.println("RTC is NOT running!");
if (! rtc.begin()) {
Serial1.println("Couldn't find RTC");
while (1);
Serial1.end();
#include "Arduino.h"
#include "U8g2lib.h"
#include "U8x8lib.h"
#include "RTClib.h"
#include "Wire.h"
#include "SPI.h"
U8G2_SSD1306_128X32_UNIVISION_F_SW_I2C u8g2(U8G2_R0, /* clock=*/ SCL, /* data=*/ SDA, /* reset=*/ U8X8_PIN_NONE); // Adafruit Feather M0 Basic Proto + FeatherWing OLED
RTC_DS1307 rtc;
while (1);
Serial1.end();
Serial2.begin(9600);
while (!Serial2) {
; // wait for Serial2 port to connect. Needed for native USB port only
u8g2.begin();
u8g2.clearBuffer();
u8g2.setFont(u8g2_font_6x13_te);
u8g2.drawStr(30, 25, "WELCOME!");
u8g2.sendBuffer();
delay(2000);
Serial2.setTimeout(1100);
u8g2.clearBuffer();
u8g2.drawUTF8(0,12,"IrmsB:");
u8g2.setCursor(55,12);
//u8g2.print(EepromA);
u8g2.setCursor(100,12);
u8g2.print("Amper");
u8g2.drawUTF8(0,22,"Hour:");
u8g2.setCursor(55,22);
// u8g2.print(EepromB);
u8g2.setCursor(100,22);
u8g2.print("Wh");
u8g2.drawUTF8(0,32,"MALİYET:");
u8g2.setCursor(55,32);
// u8g2.print(EepromC);
u8g2.setCursor(100,32);
u8g2.print("TRY");
u8g2.sendBuffer();
delay(50);
No problem, thank you for your reply. Mega SDA SCL pins and 20 21 pins seem also electrically connected. What should i do for working these OLED and DS1307 real time clock together? Any ideas?
