Using Serial Monitor Data to move a Stepper
Hello, I am new to Arduino coding and am attempting to create flight sim instruments using a stepper and the data from the simulator being pushed to the com port. I want to pull data from the serial monitor to drive a 28byj-48 stepper motor using the accelstepper library. I have the code figured out to read the serial data, I'm just not sure how to drive the stepper to the current position being read. Any help would be greatly appreciated.
// Include the AccelStepper Library
#include <AccelStepper.h>
//#define HALFSTEP 8
#define motorPin1  2       // IN1 on ULN2003 ==> Blue   on 28BYJ-48
#define motorPin2  3      // IN2 on ULN2004 ==> Pink   on 28BYJ-48
#define motorPin3  4     // IN3 on ULN2003 ==> Yellow on 28BYJ-48
#define motorPin4  5    // IN4 on ULN2003 ==> Orange on 28BYJ-48
// Define step constant
#define MotorInterfaceType 8
// Creates an instance
// Pins entered in sequence IN1-IN3-IN2-IN4 for proper step sequence
AccelStepper myStepper(MotorInterfaceType, 2, 4, 3, 5);
int altl, spdl, hdgl, bnkl, pitl, varrl, varel, varil, gfol, yawl;
int alth, spdh, hdgh, bnkh, pith, varrh, vareh, varih, gfoh, yawh;
int alt, hdg, bnk, pit, spd;
double varr, vare, vari, gfo, yaw, spdtemp;
int spdval,pos;
	// set the maximum speed, acceleration factor,
	// initial speed and the target position
	myStepper.setMaxSpeed(1000.0);
	myStepper.setAcceleration(100.0);
	myStepper.setSpeed(500);
  Serial.begin(19200);
  if (Serial.available() > 0) // there is data in the buffer
    if (Serial.available() > 21) // wait until it is filled with all the bytes we need. (21 total)
      if (Serial.read() == 255) //we found the start serialdata[0]
        altl = Serial.read();//serialdata[1] // read altitute
        alth = Serial.read();//serialdata[2]
        spdl = Serial.read();//serialdata[3]// read speed
        spdh = Serial.read();//serialdata[4]
        hdgl = Serial.read();//serialdata[5]// read compass
        hdgh = Serial.read();//serialdata[6]
        pitl = Serial.read();//serialdata[7]// read pitch
        pith = Serial.read();//serialdata[8]
        bnkl = Serial.read();//serialdata[9]// read bank
        bnkh = Serial.read();//serialdata[10]
        varrl = Serial.read();//serialdata[11] // read vario raw
        varrh = Serial.read();//serialdata[12]
        varel = Serial.read();//serialdata[13]// read vario elec
        vareh = Serial.read();//serialdata[14]
        varil = Serial.read();//serialdata[15]// read vario integrated
        varih = Serial.read();//serialdata[16]
        gfol = Serial.read();//serialdata[17]// read Gforce
        gfoh = Serial.read();//serialdata[18]
        yawl = Serial.read(); //serialdata[19] // read yawstringangle
        yawh = Serial.read(); //serialdata[20]
        //All is read --> convert the bytes back into proper data
            decoded.altitudebaro = b[1] << 8 | b[2];
            decoded.speedraw = Math.Round(((b[3] << 8 | b[4]) / 100.0),2);
            //decoded.speedias = b[3] << 8 | b[4];
            decoded.compass = b[5] << 8 | b[6];
            decoded.pitch = (b[7] << 8 | b[8]) - 90; // I don't know how to forward and convert the negative values. Hence the addition of the max negative value.
            decoded.bank = (b[9] << 8 | b[10]) - 180;
            decoded.varioraw = Math.Round(((b[11] << 8 | b[12]) - 10000.0) / 100.0, 2);
            decoded.varioelec = Math.Round(((b[13] << 8 | b[14]) -10000.0) / 100.0, 2);
            decoded.varioint = Math.Round(((b[15] << 8 | b[16]) - 10000.0) / 100.0, 2);
            decoded.gforce = Math.Round(((b[17] << 8 | b[18]) / 10.0) - 10.0, 1);
            decoded.yawstring = (b[19] << 8 | b[20])-50 ;
    alt = altl << 8 | alth; //decode altitude (m)
    spdtemp = ((spdl << 8 | spdh) / 100); //decode speed (in m/s)
    hdg = hdgl << 8 | hdgh; //decode compass (deg)
    pit = (pitl << 8 | pith) - 90; //decode pitch (deg)
    bnk = (bnkl << 8 | bnkh) - 180; ////decode bank (deg)
    varr = ((varrl << 8 | varrh) / 10.0) - 100.0; //decode raw vario (m/s)
    vare = ((varel << 8 | vareh) / 10.0) - 100.0; //decode elec vario (m/s)
    vari = ((varil << 8 | varih) / 10.0) - 100.0; //decode integrated vario (m/s)
    gfo = ((gfol << 8 | gfoh) / 10.0) - 10.0; //decode gforce
    yaw = ((yawl << 8 | yawh)) - 50.0; //decode yawstringangle (deg) [-99,99] but more in the range of [-10 , 10]
    //m/s to kmph **************************
    spd = spdtemp * 3.6;
       if (spd>maxspeed) spd=maxspeed;
      spdval = map(spd, 0, maxspeed, 0, maxsteps);
       if (vari < -5) vari = -4.9;
      if (vari > 5) vari = 4.9;
	if (myStepper.distanceToGo() == 0)
		myStepper.moveTo(vare);
	myStepper.run();
You will need to home the stepper first... and inside this "homing" exercise, you will see how to use Accelstepper.
looks like your code is reading a series of bytes representing multiple binary values. have you tried printing the values to confirm that they are transmitted/received correctly?
this seems like an awkward approach. how do you know you are reading the frist byte in the sequence when you start reading data? data like this is typically delimited by a start and possibly end sequences.
a common simplistic approach is to send the data in human readable strings terminated with a newline using Serial.readBytesUntil() to read a complete line before processing
as for the stepper ... besides the lack of "homing", without specifying some target position, possibly when the value is read from serial interface, i don't see how the distanceToGo() will be anything other than zero.
... and yes, if a new target is received before the motor has reached a previous target, it may need to change direction before reaching the previous targer
