but focuses on a certain aspect that is - somehow - more general.
This is the reason why I decided to post it as its own thread. @moderators: I'm aware of the rule of not crossposting. This question is generalised and this is the reason why I see it not as a cross-posting.
I'm using a code that uses sha1-encryption like this:
FYI, SHAx is not an encryption algorithm, but rather a hashing algorithm. The output of hashing is a message that can't be converted back to the original message, unlike encryption, where an encrypted message can be decrypted back with the correct keys.
thank you for clearing up this.
I read some intructional material about google-authenticator and learned they still use sha1 (which is the 160bit hash)
best regards Stefan
sha1 has just 160 bits. i don't believe you can recreate the original data from a hashing function especially when the hash value has fewer bits that the original data.
and of course other data sets can produce the same sha value, similar to checksums
thank you for taking time to post. I came to the conclusion that changing from sha1 to sha256 is not suitable in this case. In addition this means my initial question which sha256-library is easy to use and independant of other libraries = standalone usable has become obsolete.
