using speaker for talking arduino
i have a project and i need to make it talks , i am using the talkie library and i have
include "talkie.h"
Talkie voice;
const int8_t spDinar[] PROGMEM = {0x0A,0x28,0xA5,0x72,0xE8,0x29,0x89,0x6B,0xB0,0xD2,0x61,0xA7,0x40,0xAE,0x2D,0x4A,0x86,0x13};
this is one of the examples in this library
my problem is
i know how to transform voice file to hex to give arduino the ability of spilling it i am using the HxD hex editor to find the hex
but the HxD is giving a very lot of hex values such as this
FF F3 44 C4 00 12 72 82 18 00 08 44 B9 64 00 00 C6 CC 08 63 18 E0 44 00 66 31 E0 00 00 00 79 8C 71 8F 00 01 C1 FF F0 2F 7D 4E 7E 42 35 4E 7F D5 ED F5 39 CF 3B C8 46 E4 65 7D 09 CE 7E 84 3B A9 DF EA 77 90 99 CF CE 2C F3 3F F3 3C 3C B0 04 73 0C E9 E0 61 E1 EF 9D 0C CE 41 44 91 AD 12 B6 30 FF F3 44 C4 09 12 70 42 24 00 18 C6 25 A4 BF A0 54 59 3D 17 4D E9 B4 F3 87 02 AB 8E FE DE FD EA F6 B4 D9 3F C9 82 B1 4F FF 0E EF 22 F8 57 0E FB DC 57 FF FB 07 42 5F BB DF FC 20 A9 82 61 45 24 37 BE 6B 30 4D 0A C4 10 DE FC 23 AF FE 49 88 88
but the arduino should find values like that 0x00
it is very hard to write all the values by hand
is there any way or hex editor to make it more easier ?
I would tend to think impossible rather than very hard.
You do not have a waveform as an input but compressed data. The compression used is called a Linear Predictive Encoder, so you need to run your sound samples through some software that will do that for you. This was an encoded format famous used in the old “Speak and spell “ toys of the 80s.
Unfortunately I don’t know of any software that will do this but there must be some somewhere.
If all you want to do is prefix 0x to each number then write a small piece of code to read these values and print them out with 0x first. You can treat the numbers as strings. Then copy them from the serial monitor and paste them into your program.
thanks for your reply
the idea of using the serial monitor was in my head all the time but i don't know how to do that because i have a very lot of numbers and i can't put 0x before each one of them
i am trying to use Exel to format the values to 0x00, but i have a problem
because some times some values does not change
Isra2006:
You do it programmatically, write the code to do it once and put it in a loop.
Where are these numbers you want to convert?
