Using TABS within the sketch
hello all,thanks for your time first and foremost,to get things out of the way first i cannot post my code it is to big so i will give a quick run down.
im using a oled for my project and have multiples of image bitmaps stored in the main sketch and i wanted to open a new file(which i did) to store all the global bitmaps and sketch dependency's but when i try to call the const unsigned char for that picture bit map it says "'picture_1' was not declared in this scope;" because it is in the second file and not technically in the first file that the main sketch is in,
so to simplify i am trying to use a second file to hold all the ugly bitmaps but when i call the bitmap from the second file it says it is undefined in the main sketch could someone tell me what i am doing wrong here?
please and thank you =)
const unsigned char blink_1 [] PROGMEM ={
0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
  0x0, 0x0, 0x7f, 0xff, 0xff, 0xf0, 0x0, 0x0, 0x0, 0x0, 0xf, 0xff,
  0xff, 0xf8, 0x0, 0x0, 0x0, 0x0, 0xff, 0xff, 0xff, 0xf8, 0x0, 0x0,
  0x0, 0x0, 0x3f, 0xff, 0xff, 0xfe, 0x0, 0x0, 0x0, 0x1, 0xff, 0xff,
  0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x7f, 0xff, 0xff, 0xff, 0x0, 0x0,
  0x0, 0x3, 0xff, 0xff, 0xff, 0xfe, 0x0, 0x0, 0x0, 0x0, 0xff, 0xff,
  0xff, 0xff, 0x80, 0x0, 0x0, 0x7, 0xff, 0xff, 0xff, 0xff, 0x0, 0x0,
  0x0, 0x1, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x0, 0x0, 0xf, 0xff, 0xff,
  0xff, 0xff, 0x80, 0x0, 0x0, 0x1, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x0,
  0x0, 0xf, 0xff, 0xff, 0xff, 0xff, 0x80, 0x0, 0x0, 0x3, 0xff, 0xff,
  0xff, 0xff, 0xe0, 0x0, 0x0, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x0,
  0x0, 0x7, 0xff, 0xff, 0xff, 0xff, 0xf0, 0x0, 0x0, 0x3f, 0xff, 0xff,
  0xff, 0xff, 0xe0, 0x0, 0x0, 0xf, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x0,
  0x0, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xe0, 0x0, 0x0, 0xf, 0xff, 0xff,
  0xff, 0xff, 0xf8, 0x0, 0x0, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xf0, 0x0,
  0x0, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x0, 0x0, 0x7f, 0xff, 0xff,
  0xff, 0xff, 0xf0, 0x0, 0x0, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x0,
  0x0, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xf0, 0x0, 0x0, 0x1f, 0xff, 0xff,
  0xff, 0xff, 0xfc, 0x0, 0x0, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x0,
  0x0, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x0, 0x0, 0xff, 0xff, 0xff,
  0xff, 0xff, 0xf8, 0x0, 0x0, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x0,
  0x1, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x0, 0x0, 0x7f, 0xff, 0xff,
  0xff, 0xff, 0xff, 0x0, 0x1, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x0,
  0x0, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x0, 0x1, 0xff, 0xff, 0xff,
  0xff, 0xff, 0xfc, 0x0, 0x0, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x0,
  0xff, 0xff, 0xff, 0x0, 0x3, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x0,
  0x0, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xff, 0x0, 0x3, 0xff, 0xff, 0xff,
  0xff, 0xff, 0xfe, 0x0, 0x0, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80,
  0x3, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x0, 0x0, 0xff, 0xff, 0xff,
  0xff, 0xff, 0xff, 0x80, 0x3, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x0,
  0x0, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80, 0x3, 0xff, 0xff, 0xff,
  0x0, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x0, 0x0, 0x3f, 0xff, 0xff,
  0xff, 0xff, 0xfe, 0x0, 0x0, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x0,
  0x0, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x0, 0x0, 0x7f, 0xff, 0xff,
  0xff, 0xff, 0xfc, 0x0, 0x0, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xf0, 0x0,
  0x0, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x0, 0x0, 0x3f, 0xff, 0xff,
  0xff, 0xff, 0xf8, 0x0, 0x0, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x0,
  0x0, 0x7, 0xff, 0xff, 0xff, 0xff, 0xf0, 0x0, 0x0, 0xf, 0xff, 0xff,
  0xff, 0xff, 0x80, 0x0, 0x0, 0x3, 0xff, 0xff, 0xff, 0xff, 0xe0, 0x0,
  0x0, 0xf, 0xff, 0xff, 0xff, 0xff, 0x80, 0x0, 0x0, 0x1, 0xff, 0xff,
  0xff, 0xff, 0xc0, 0x0, 0x0, 0x7, 0xff, 0xff, 0xff, 0xff, 0x0, 0x0,
  0x0, 0x1, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x0, 0x0, 0x3, 0xff, 0xff,
  0xff, 0xfe, 0x0, 0x0, 0x0, 0x0, 0xff, 0xff, 0xff, 0xff, 0x80, 0x0,
  0x0, 0x1, 0xff, 0xff, 0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x7f, 0xff,
  0xff, 0xff, 0x0, 0x0, 0x0, 0x0, 0xff, 0xff, 0xff, 0xf8, 0x0, 0x0,
  0x0, 0x0, 0x3f, 0xff, 0xff, 0xfe, 0x0, 0x0, 0x0, 0x0, 0x7f, 0xff,
  0xff, 0xf0, 0x0, 0x0, 0x0, 0x0, 0xf, 0xff, 0xff, 0xf8, 0x0, 0x0,
  0x0, 0x0, 0x1f, 0xff, 0xff, 0xc0, 0x0, 0x0, 0x0, 0x0, 0x7, 0xff,
  0xff, 0xf0, 0x0, 0x0, 0x0, 0x0, 0x7, 0xff, 0xff, 0x0, 0x0, 0x0,
  0x0, 0x0, 0x1, 0xff, 0xff, 0xc0, 0x0, 0x0, 0x0, 0x0, 0x1, 0xff,
  0xfc, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x7f, 0xff, 0x0, 0x0, 0x0,
  0x0, 0x0, 0x0, 0x3f, 0xe0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0xf,
  0xf8, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
  0x0, 0x0, 0x0, 0x0,};
const unsigned char blink_2 [] PROGMEM ={0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
  0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x7, 0xff, 0xff,
  0xff, 0xff, 0x0, 0x0, 0x0, 0x1, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x0,
  0xff, 0xff, 0xe0, 0x0, 0x0, 0xf, 0xff, 0xff, 0xff, 0xff, 0x80, 0x0,
  0x0, 0x3, 0xff, 0xff, 0xff, 0xff, 0xe0, 0x0, 0x0, 0x1f, 0xff, 0xff,
  0xff, 0xff, 0xc0, 0x0, 0x0, 0x7, 0xff, 0xff, 0xff, 0xff, 0xf0, 0x0,
  0x0, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xe0, 0x0, 0x0, 0x7, 0xff, 0xff,
  0xff, 0xff, 0xf0, 0x0, 0x0, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xe0, 0x0,
  0x0, 0xf, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x0, 0x0, 0x3f, 0xff, 0xff,
  0xff, 0xff, 0xf0, 0x0, 0x0, 0xf, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x0,
  0x0, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x0, 0x0, 0xff, 0xff, 0xff,
  0xff, 0xff, 0xf8, 0x0, 0x0, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x0,
  0xff, 0xff, 0xfc, 0x0, 0x0, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x0,
  0x1, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x0, 0x0, 0x3f, 0xff, 0xff,
  0x0, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x0, 0x0, 0x1f, 0xff, 0xff,
  0xff, 0xff, 0xfe, 0x0, 0x0, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xf0, 0x0,
  0x0, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xe0, 0x0, 0x0, 0xf, 0xff, 0xff,
  0xff, 0xff, 0xf8, 0x0, 0x0, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xe0, 0x0,
  0x0, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x0, 0x0, 0x7, 0xff, 0xff,
  0xff, 0xff, 0xf0, 0x0, 0x0, 0xf, 0xff, 0xff, 0xff, 0xff, 0x80, 0x0,
  0x0, 0x3, 0xff, 0xff, 0xff, 0xff, 0xe0, 0x0, 0x0, 0xf, 0xff, 0xff,
  0x0, 0x7, 0xff, 0xff, 0xff, 0xff, 0x0, 0x0, 0x0, 0x1, 0xff, 0xff,
  0xff, 0xff, 0xc0, 0x0, 0x0, 0x3, 0xff, 0xff, 0xff, 0xfe, 0x0, 0x0,
  0x0, 0x0, 0xff, 0xff, 0xff, 0xff, 0x80, 0x0, 0x0, 0x1, 0xff, 0xff,
  0x0, 0x0, 0xff, 0xff, 0xff, 0xf8, 0x0, 0x0, 0x0, 0x0, 0x3f, 0xff,
  0xff, 0xfe, 0x0, 0x0, 0x0, 0x0, 0x7f, 0xff, 0xff, 0xf0, 0x0, 0x0,
  0x0, 0x0, 0x1f, 0xff, 0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x3f, 0xff,
  0xff, 0xe0, 0x0, 0x0, 0x0, 0x0, 0xf, 0xff, 0xff, 0xf0, 0x0, 0x0,
  0x0, 0x0, 0xf, 0xff, 0xff, 0x80, 0x0, 0x0, 0x0, 0x0, 0x3, 0xff,
  0xff, 0xe0, 0x0, 0x0, 0x0, 0x0, 0x3, 0xff, 0xfe, 0x0, 0x0, 0x0,
  0x0, 0x0, 0x0, 0xff, 0xff, 0x80, 0x0, 0x0, 0x0, 0x0, 0x0, 0x7f,
  0xf8, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x1f, 0xfc, 0x0, 0x0, 0x0,
const unsigned char blink_3 [] PROGMEM ={0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
  0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x1f, 0xff, 0xff,
  0xff, 0xff, 0xe0, 0x0, 0x0, 0x7, 0xff, 0xff, 0xff, 0xff, 0xf0, 0x0,
  0x0, 0xf, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x0, 0x0, 0x7f, 0xff, 0xff,
  0xff, 0xff, 0xf0, 0x0, 0x0, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x0,
  0xff, 0xff, 0xf8, 0x0, 0x0, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x0,
  0x0, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf0, 0x0, 0x0, 0x1f, 0xff, 0xff,
  0x0, 0x7f, 0xff, 0xff, 0xff, 0xff, 0xf0, 0x0, 0x0, 0xf, 0xff, 0xff,
  0xff, 0xff, 0xfc, 0x0, 0x0, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xe0, 0x0,
  0x0, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x0, 0x0, 0x7, 0xff, 0xff,
  0xff, 0xff, 0xf0, 0x0, 0x0, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x0,
  0x0, 0x7, 0xff, 0xff, 0xff, 0xff, 0xf0, 0x0, 0x0, 0x1f, 0xff, 0xff,
  0xff, 0xff, 0xe0, 0x0, 0x0, 0x7, 0xff, 0xff, 0xff, 0xff, 0x0, 0x0,
  0x0, 0x1, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x0, 0x0, 0x7, 0xff, 0xff,
  0xff, 0xff, 0x80, 0x0, 0x0, 0x1, 0xff, 0xff, 0xff, 0xfc, 0x0, 0x0,
  0x0, 0x0, 0x7f, 0xff, 0xff, 0xff, 0x0, 0x0, 0x0, 0x0, 0xff, 0xff,
  0xff, 0xf8, 0x0, 0x0, 0x0, 0x0, 0x3f, 0xff, 0xff, 0xfe, 0x0, 0x0,
  0x0, 0x0, 0x7f, 0xff, 0xff, 0xf0, 0x0, 0x0, 0x0, 0x0, 0x1f, 0xff,
  0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x3f, 0xff, 0xff, 0xe0, 0x0, 0x0,
  0x0, 0x0, 0xf, 0xff, 0xff, 0xf0, 0x0, 0x0, 0x0, 0x0, 0xf, 0xff,
  0xff, 0x80, 0x0, 0x0, 0x0, 0x0, 0x3, 0xff, 0xff, 0xe0, 0x0, 0x0,
  0x0, 0x0, 0x3, 0xff, 0xfe, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0xff,
  0xff, 0x80, 0x0, 0x0, 0x0, 0x0, 0x0, 0x7f, 0xf8, 0x0, 0x0, 0x0,
  0x0, 0x0, 0x0, 0x1f, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
  0x0, 0x0, 0x0, 0x0, };
const unsigned char blink_4 [] PROGMEM ={0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
  0x0, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xe0, 0x0, 0x0, 0x7, 0xff, 0xff,
  0x0, 0x1f, 0xff, 0xff, 0xff, 0xff, 0x80, 0x0, 0x0, 0x3, 0xff, 0xff,
  0x0, 0x0, 0xff, 0xff, 0xff, 0xff, 0x80, 0x0, 0x0, 0x3, 0xff, 0xff,
  0xff, 0xf0, 0x0, 0x0, 0x0, 0x0, 0x1f, 0xff, 0xff, 0xfc, 0x0, 0x0,
  0x0, 0x0, 0x3f, 0xff, 0xff, 0xe0, 0x0, 0x0, 0x0, 0x0, 0xf, 0xff,
  0xff, 0xf0, 0x0, 0x0, 0x0, 0x0, 0xf, 0xff, 0xff, 0x80, 0x0, 0x0,
  0x0, 0x0, 0x3, 0xff, 0xff, 0xe0, 0x0, 0x0, 0x0, 0x0, 0x3, 0xff,
  0xfe, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0xff, 0xff, 0x80, 0x0, 0x0,
  0x0, 0x0, 0x0, 0x7f, 0xf8, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x1f,
  0xfc, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
const unsigned char blink_5 [] PROGMEM ={0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
  0x0, 0x0, 0x0, 0x0, 0x0, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xe0, 0x0,
  0x0, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x0, 0x0, 0x3, 0xff, 0xff,
  0x0, 0xf, 0xff, 0xff, 0xff, 0xff, 0x0, 0x0, 0x0, 0x1, 0xff, 0xff,
  0x0, 0x0, 0x7f, 0xff, 0xff, 0xff, 0x0, 0x0, 0x0, 0x1, 0xff, 0xff,
const unsigned char blink_6 [] PROGMEM ={0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
  0x0, 0x0, 0x0, 0x0, 0x0, 0xf, 0xff, 0xff, 0xff, 0xff, 0x80, 0x0,
  0x0, 0x7, 0xff, 0xff, 0xff, 0xfe, 0x0, 0x0, 0x0, 0x0, 0xff, 0xff,
  0xff, 0xff, 0x80, 0x0, 0x0, 0x3, 0xff, 0xff, 0xff, 0xfe, 0x0, 0x0,
  0x0, 0x0, 0x3f, 0xff, 0xff, 0xfe, 0x0, 0x0, 0x0, 0x0, 0xff, 0xff,
const unsigned char blink_7 [] PROGMEM ={0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
  0x0, 0x0, 0x1f, 0xff, 0xff, 0xfc, 0x0, 0x0, 0x0, 0x0, 0x7f, 0xff,
const unsigned char blink_8 [] PROGMEM ={0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
  0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x3f, 0xff,
for anyone who needs the sketch of the second file i created here it is pretty straight forward but i dont know if i need to add anything to this to make it call-able to the other sketch or maybe if i need to wrap this all into a function to make it retrievable in the sketch?
Is this a tutorial ?
I figured it out 5 mins after posting i just cant delete this post now
Hi @do_not_sleep. Congratulations on finding a solution!
Please add a reply to the public forum topic that gives a summary of your findings. That will be much appreciated by those who have similar questions in the future and find your post while researching for a solution.
You can then click the " Solution" control on the reply where you described the solution:
This will cause the topic to be marked as solved.
Regards,
Per
so yes my assumption was correct the global variables and data can be put into a separate tab but it must be wrapped in a call back function in order to be used in the main sketch
