Using the CD74HC4067 multiplexer with push buttons
Hello, Im trying to use the CD74HC4067 multiplexer with push buttons. My goal is simple, to connect push buttons to the CD74HC4067 and have it print each channels state, if the button on that specific channel is "pressed" or "not pressed". I have tried several different codes and I have been researching for about a month now with no success. I have tried a ton of different librarys and even tried to do the code for myself. Im in desperate need of some help.
Here is the code im trying to get to work:
//Mux control pins
int s0 = 8;
int s1 = 9;
int s2 = 10;
int s3 = 11;
//Mux in “SIG” pin
int SIG_pin = 0;
void setup(){
pinMode(s0, OUTPUT);
pinMode(s1, OUTPUT);
pinMode(s2, OUTPUT);
pinMode(s3, OUTPUT);
digitalWrite(s0, LOW);
digitalWrite(s1, LOW);
digitalWrite(s2, LOW);
digitalWrite(s3, LOW);
void loop(){
//Loop through and read all 16 values
//Reports back Value at channel 6 is: 346
for(int i = 0; i < 16; i ++){
  Serial.print("Value at channel ");
  Serial.print(i); Serial.print("is : ");
  Serial.println(readMux(i));
  int readMux(int channel){
    int controlPin[] = {s0, s1, s2, s3};
    int muxChannel[16][4]={ {0,0,0,0},
    {1,0,0,0},
    {0,1,0,0},
    {1,1,0,0},
    {0,0,1,0},
    {1,0,1,0},
    {0,1,1,0},
    {1,1,1,0},
    {0,0,0,1},
    {1,0,0,1},
    {0,1,0,1},
    {1,1,0,1},
    {0,0,1,1},
    {1,0,1,1},
    {0,1,1,1},
    {1,1,1,1} };
    //loop through the 4 sig
    for(int i = 0; i < 4; i ++){
      digitalWrite(controlPin[i], muxChannel[channel][i]);
      //read the value at the SIG pin
      int val = analogRead(SIG_pin); //return the value
      return val;
Here is the schematic:
there are several errors in your code
for(int readMux(int channel)){
i think you want
for(int channel = 0; channel < 16; channel++){
aren't there only 4, not 6 select pins
for(int i = 0; i < 6; i ++){ //loop through the 4 sig
and what are you returning the value to from loop()? did you intend the above code to be a sub-function?
  return muxVal; //return the value
Anton-H:
//Mux control pins
int s0 = 8;
int s1 = 9;
int s2 = 10;
int s3 = 11;
//Mux in “SIG” pin
int SIG_pin = 0;
void setup(){
void loop(){
   {1,0,0,0},
   {0,1,0,0},
   {1,1,0,0},
   {0,0,1,0},
   {1,0,1,0},
   {0,1,1,0},
   {1,1,1,0},
   {0,0,0,1},
   {1,0,0,1},
   {0,1,0,1},
   {1,1,0,1},
   {0,0,1,1},
   {1,0,1,1},
   {0,1,1,1},
   {1,1,1,1} };
     return val;
there are no errors in your code.
However...
According to your schematic you also have EN = 7
so you need to initialise that pin as well ie
pinMode(en, OUTPUT);
digitalWrite(en, LOW); //if in setup, should permanently enable the board.
then you have SIG_PIN wired to pin 3 which is NOT an analog pin. so again you need to initialise it
pinMode(SIG_PIN, INPUT);
then in 'int readMux(int channel)'
change
to
int val = digitalRead(SIG_pin); //return the value
so something like this in code (compiles NOT tested!)
//Mux control pins
int en = 7;
int s0 = 8;
int s1 = 9;
int s2 = 10;
int s3 = 11;
//Mux in "SIG" pin
int SIG_pin = 3;
  pinMode(SIG_pin, INPUT);
  for (int i = 0; i < 16; i ++) {
int readMux(int channel) {
  int muxChannel[16][4] = { {0, 0, 0, 0},
                            {1, 0, 0, 0},
                            {0, 1, 0, 0},
                            {1, 1, 0, 0},
                            {0, 0, 1, 0},
                            {1, 0, 1, 0},
                            {0, 1, 1, 0},
                            {1, 1, 1, 0},
                            {0, 0, 0, 1},
                            {1, 0, 0, 1},
                            {0, 1, 0, 1},
                            {1, 1, 0, 1},
                            {0, 0, 1, 1},
                            {1, 0, 1, 1},
                            {0, 1, 1, 1},
                            {1, 1, 1, 1}
  for (int i = 0; i < 4; i ++) {
  return val;
hope that helps
hc4067.cpp: In function 'void loop()':
hc4067.cpp:29:30: warning: declaration of 'int readMux(int)' has 'extern' and is initialized
hc4067.cpp:29:31: error: expected ';' before ')' token
hc4067.cpp:29:31: error: expected primary-expression before ')' token
I have solved the issue by switching the multiplexer, aparently i had managed to burn the other one. Thanks för all the replies.
