Using the hardware serial pins to play audio files with a button press
First time posting on here. So my goal is to have 3 seperate audio files play when the button is pressed i.e button press audio file 1 plays when its done it stops playing. When the button is pressed again it plays audio file 2, all the way up to 3 times on the fourth i dont need an audio file so this will be just a blank spot for a future part of the project. But then repeat the cycle after that. Right now this is the code i have (posted below) I'm new to the serial function. Right now how its setup in the code is that im testing with just the first audio file but it plays continuously and i have even pressed a button yet. My two boards are the adafruit feather m4 express and the mini fx sound board ogg/wav trigger 16mb with wires connected from sound to micro rx-tx, tx-rx Gnd-Gnd, audio pin 1- digital pin 13 both boards are powered seperately as well. The button is a tactile button switch
#include <Adafruit_Soundboard.h>  // Include the Adafruit Audio FX Sound Board library
#define BUTTON_PIN 6       // Pin connected to the button
#define SOUNDBOARD_PIN 1   // Pin connected to the Adafruit Audio FX Sound Board trigger input
// Initialize Serial1 for communication with Soundboard
Uart soundboardSerial(&sercom1, 1, 0, SERCOM_RX_PAD_1, UART_TX_PAD_0);  // Serial1 for Feather M4 Express
Adafruit_Soundboard sfx(&Serial, &soundboardSerial, SOUNDBOARD_PIN);
int buttonState = HIGH; // Variable to track button state
int audioTrack = 1;     // Variable to track current audio track
bool audioPlayed = false; // Flag to track if audio has been played
  pinMode(BUTTON_PIN, INPUT_PULLUP); // Use INPUT_PULLUP to enable internal pull-up resistor
  pinMode(SOUNDBOARD_PIN, OUTPUT);   // Set the sound board trigger pin as output
  // Initialize the hardware serial port for communication with the Soundboard
  Serial.begin(9600);  // Adjust baud rate as needed
  soundboardSerial.begin(9600);
  // Allow time for Soundboard to boot up
  // No need for sfx.begin(); as Adafruit Soundboard does not have a begin() function
  int currentButtonState = digitalRead(BUTTON_PIN);
  // Check if button is pressed (LOW) and was not pressed before
  if (currentButtonState == LOW && buttonState == HIGH) {
    audioPlayed = false; // Reset audio flag
    buttonState = LOW;   // Update button state
    PlayNextAudioTrack(); // Play the next audio track
  } else if (currentButtonState == HIGH && buttonState == LOW) {
    buttonState = HIGH; // Update button state when released
void PlayNextAudioTrack() {
  if (!audioPlayed) {
    sfx.stopTrack(); // Stop any currently playing track
    sfx.playTrack(audioTrack); // Play the current audio track
    audioPlayed = true; // Set the flag after audio is played
    audioTrack++; // Increment to the next audio track
    if (audioTrack > 3) {
      audioTrack = 1; // Cycle back to the first track after the third track
