Hello, I was wondering if anyone could help with a problem with the serial monitor
In this project I have a master Arduino that I am reading the value ADC A0 value from a 10k potentiometer (adjusts the voltage between 0 - 3.3V) and sends the value over serial0 to a slave Arduino Due. The slave Arduino Due, takes the value it receives and outputs it on the DAC in the voltage range 0.55 - 2.7 V). This works ok
However, I would like to display the incoming serial value on the slave Due's on the serial monitor. When I try to do this nothing appears on the slave's serial monitor. I think it might have something to do with the line: int val = Serial.parseInt(); which is what I use to convert the incoming serial chars into ints for the DAC. When I remove this line I am able to see the value on the serial monitor, but I lose the ability to output the value on the slave's DAC
I have looked all over the internet for a solution without much luck.
Can anyone help with finding away to output the 0.55 - 2.75V on the DAC whilst monitoring the incoming serial values on the serial monitor?
Many thanks in advance
My code for the master and slave Arduinos can be seen below:
Master Arduino
// initalize serial communication at 9600 bits per second:
//the loop routine runs over and over again forever:
// read the input on analog pin 0:
int sensorValue = analogRead(A0);
Serial.println(sensorValue);
delay(30); //delay in between reads for stability
Slave Arduino
int val;
analogWriteResolution(8);
pinMode(DAC0, OUTPUT);
char z;
if (Serial.available()>0)
z = Serial.read();
Serial.print(z);
analogWrite(DAC0, val);
