Using two encoders on one Arduino Mega 2560, second channel will only count up
I am trying to use two encoders on one Arduino Mega 2560, on encoder for each wheel.
The first channel using Pin A=2 and Pin B=4, works great no issues.
The second channel using Pin A=3 and Pin B=4, the interrupt comes thru but it will only count in one direction).
If I put the encode for the second channel on the first channel, it works fine.
Any ideas?
Here is the code:
// Rotary Encoder Inputs
//Pin 2 and 3 can have external interrupts on them
//Pin 18 and 19 can also have external interrupts
int Encoder1_PinA = 2;
int Encoder1_PinB = 4;
int Encoder1_counter_2 = 0;
volatile int Encoder1_counter = 0;
int Encoder2_PinA = 3;
int Encoder2_PinB = 5;
int Encoder2_counter_2 = 0;
volatile int Encoder2_counter = 0;
volatile int Encode1_PinB_Value =0;
volatile int Encode2_PinB_Value =0;
char in_char;
unsigned long my_time;
String send, send2, info, info2, tab = "\t";
unsigned long start, stop, elapsed;
int Encoder1_pin_a = Encoder1_PinA, Encoder1_pin_b = Encoder1_PinB;
int Encoder2_pin_a = Encoder2_PinA, Encoder2_pin_b = Encoder2_PinB;
pinMode(Encoder1_PinA, INPUT);
pinMode(Encoder1_PinB, INPUT);
pinMode(Encoder2_PinA, INPUT);
pinMode(Encoder2_PinB, INPUT);//INPUT_PULLUP
//PCMSK2 |= (1 << PCINT18) | (1 << PCINT19);
start = millis();
attachInterrupt(digitalPinToInterrupt(Encoder1_pin_a), Encoder1_change, RISING);
attachInterrupt(digitalPinToInterrupt(Encoder2_pin_a), Encoder2_change, RISING);
Serial.println("Ready to go");
void Encoder1_change()
Encode1_PinB_Value =digitalRead(Encoder1_pin_b);
if (Encode1_PinB_Value == HIGH)
Encoder1_counter = Encoder1_counter - 1;
Encoder1_counter = Encoder1_counter + 1;
void Encoder2_change()
Encode2_PinB_Value =digitalRead(Encoder2_pin_b);
if (Encode2_PinB_Value == HIGH)
Encoder2_counter = Encoder2_counter - 1;
Encoder2_counter = Encoder2_counter + 1;
void DisplayPins()
Serial.print(" Encoder1[");
if (digitalRead(Encoder1_pin_a) == HIGH)
Serial.print("PinA=High ");
Serial.print("PinA=Low ");
if (digitalRead(Encoder1_pin_b) == HIGH)
Serial.print(" PinB=High ");
Serial.print(" PinB=Low ");
Serial.print(" PinB_Value="); Serial.print(Encode1_PinB_Value, DEC);
Serial.print("] ");
Serial.print(" Encoder2[");
if (digitalRead(Encoder2_pin_a) == HIGH)
if (digitalRead(Encoder2_pin_b) == HIGH)
Serial.print("PinB=High ");
Serial.print("PinB=Low ");
Serial.print(" PinB_Value="); Serial.print(Encode2_PinB_Value, DEC);
Serial.println("]");
if (Encoder1_counter != Encoder1_counter_2)
noInterrupts();
info = (String)Encoder1_counter;
Encoder1_counter_2 = Encoder1_counter;
interrupts();
send = info;
Serial.print("1-->");
Serial.print(send);
DisplayPins();
if (Encoder2_counter != Encoder2_counter_2)
noInterrupts();
info2 = (String)Encoder2_counter;
Encoder2_counter_2 = Encoder2_counter;
interrupts();
send = info;
send2 =info2;
Serial.print("2-->");
Serial.print(" [1]-->");
Serial.print(send);
Serial.print(" [2]-->");
Serial.print(send2);
DisplayPins();
while (Serial.available() > 0)
char ch = Serial.read();
Serial.print(ch);
if(ch =='r')
Serial.println("Reset encoder");
noInterrupts();
Encoder1_counter=0;
Encoder1_counter_2= 0;
interrupts();
if(ch == 'i')
DisplayPins();
you might find reading this other thread helpful, https://forum.arduino.cc/index.php?topic=681420.0, He's working on code to service 43 encoders.
if you have a single routine that works for one encoder, it should work for another encoder
Please edit your post to add code tags, as described in "How to use this forum".
Not sure I can see why the two encoders are different (why not using INPUT_PULLUP everywhere?)
But I notice a lack of critical section covering some variable accesses:
 if (Encoder1_counter != Encoder1_counter_2)  <<< Encoder1_counter read not in critical section
    noInterrupts();
    info = (String)Encoder1_counter;  <<< read in critical section, but greatly slowed by allocating a String
    interrupts();
    send = info;
    Serial.print(send);
    DisplayPins();
You should be putting all variable access in one critical section and do nothing else but copy them to locals:
  noInterrupts() ;
  int counter_copy = Encoder1_counter ;  // read variable once in critical section, as quick as possible
  interrupts() ;
  if (counter_copy != Encoder1_counter_2)
    Encoder1_countre_2 = counter_copy ;
    info = (String) counter_copy;
    send = info;
    Serial.print(send);
    DisplayPins();
