using two softwareserial in the code..!
Hi everyone!
I need to use two softwareserial object but when I run it, I cannot recieve anything from the last created softwareserial object…
What should I do?
I have already read examples but its just working technically not in practise…
I tried to take coordinates for 6 times then start the gsm modem but It is not working too…
My code is trying to communicate with a GPS and GSM Modem…
Pls help, I need some advice or solution… ??? :astonished: :astonished:
#include <TinyGPS.h>
#include <EEPROM.h>
#include <SoftwareSerial.h>
#define  inDataLENTGTH 128
// Bora Ciner -- GSM Modem Home Control System
TinyGPS gps;
SoftwareSerial gsmSerial(2, 3); //SoftwareSerial(rxPin, txPin);
SoftwareSerial ss(5,6);
boolean debug = true;
const int SICAKLIK_PORT =12;
const int ROLEPin1 = 6;     // isiklarin bagli oldugu pin
const int ROLEPin2 = 7;     // isiklarin bagli oldugu pin
const int ROLEPin3 = 8;     // isiklarin bagli oldugu pin
const int ROLEPin4 = 9;     // isiklarin bagli oldugu pin
const int ROLEPin5 = 10;     // isiklarin bagli oldugu pin
const int ROLEPin6 = 11;     // isiklarin bagli oldugu pin
String inData = String(inDataLENTGTH); // Allocate some space for the string
boolean inputAvailable = false;
String strWhichMsg = String(1);
String NewMessageDEF = String(15);
String MessageReadString = String(10);
String readingFromInbox = String(10);
String sendReadRequest = String(10);
String PASSWORD = String();
String RemoveCommand = String("AT+CMGD=");
String ADMIN_PHONE_NUMBER = String(11);
String DurumBilgisiStr = String(150);
int gpsoku=true;
  gsmSerial.begin(9600);
  ss.begin(9600);
  pinMode(ROLEPin1, OUTPUT);
  pinMode(ROLEPin2, OUTPUT);
  pinMode(ROLEPin3, OUTPUT);
  pinMode(ROLEPin4, OUTPUT);
  pinMode(ROLEPin5, OUTPUT);
  pinMode(ROLEPin6, OUTPUT);
  digitalWrite(ROLEPin1,HIGH);
  digitalWrite(ROLEPin2,HIGH);
  digitalWrite(ROLEPin3,HIGH);
  digitalWrite(ROLEPin4,HIGH);
  digitalWrite(ROLEPin5,HIGH);
  digitalWrite(ROLEPin6,HIGH);
  NewMessageDEF = "+CMTI: \"SM\",";
  strWhichMsg = "";
  MessageReadString = "at+cmgr=";
  readingFromInbox = "REC UNREAD";
  ReadPasswordFromEEPROM();
  Serial.print("PASSWORD =");
  Serial.println(PASSWORD);
  if(debug)
  Serial.println("Setup..! wait for 1 sec");
  Serial.print("_SS_MAX_RX_BUFF = ");
  Serial.println(_SS_MAX_RX_BUFF);
void loop() // run over and over
bool newData = false;
  unsigned long chars;
  unsigned short sentences, failed;
 if(gpsoku <=5)
    while (ss.available())
      char c = ss.read();
      //Serial.write(c); // uncomment this line if you want to see the GPS data flowing
      if (gps.encode(c)) // Did a new valid sentence come in?
          printGPSDATA();
          gpsoku++;
  else{
  //-------------------GSM---------------------
  while(gsmSerial.available() > 0 )
    inputAvailable = true;
    int tmp = gsmSerial.read();
    inData += (char) tmp;
    delay(7);
  if(inputAvailable){
    inputAvailable=false;
    processData();
  inData="";
void printGPSDATA(){
    float flat, flon;
    unsigned long age;
    gps.f_get_position(&flat, &flon, &age);
    Serial.print("LAT=");
    Serial.print(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : flat, 6);
    Serial.print(" LON=");
    Serial.print(flon == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : flon, 6);
    Serial.print(" SAT=");
    Serial.print(gps.satellites() == TinyGPS::GPS_INVALID_SATELLITES ? 0 : gps.satellites());
    Serial.print(" PREC=");
    Serial.println(gps.hdop() == TinyGPS::GPS_INVALID_HDOP ? 0 : gps.hdop());
void processData(){
  if(debug){
  Serial.println("OKUDUGUM VERI");
  Serial.println(inData);
  if(thereIsNewMessage())
  { // yeni mesaj var
    if(debug)Serial.println("yeni mesaj var");
    String sendReadRequest = "";
    sendReadRequest += MessageReadString;
    int indexofMsgStr = inData.indexOf(NewMessageDEF);
    indexofMsgStr += NewMessageDEF.length();
    strWhichMsg = inData.substring(indexofMsgStr , indexofMsgStr+1);
    sendReadRequest +=strWhichMsg;
    if(debug){
    Serial.print("gonderilen komut = ");
    Serial.println(sendReadRequest);
    //gsmSerial.println(sendReadRequest); // xxxx inci mesaji oku
  }else if(IsRinging())
  { // telefon caliyor
    if(debug)Serial.println("telefon caliyor");
    AramayiMesguleCevir();
    removeSms();
  }else if(ReadFromInbox())
    takeMessageBody();
    processMessageBody();
    removeSms();
  }else
    if(debug)Serial.println("ELSE");
void AramayiMesguleCevir(){
  //gsmSerial.println("AT H");
  delay(50);
void takeMessageBody(){
if(debug)Serial.println("---->takeMessageBody");
int index_of_NewLine = 0;
int indexofPhoneStr = inData.indexOf("\",\"+9");
indexofPhoneStr += 5;
ADMIN_PHONE_NUMBER = inData.substring(indexofPhoneStr , indexofPhoneStr+11);
if(debug)
  Serial.print("ADMIN PHONE NUMBER ");
  Serial.println(ADMIN_PHONE_NUMBER);
  index_of_NewLine = inData.indexOf("REC UNREAD");
  index_of_NewLine += 53;
  inData = inData.substring(index_of_NewLine,index_of_NewLine+29);
if(debug)
  Serial.println("Message Body ===>");
  Serial.println("<----takeMessageBody");
void processMessageBody(){
You really should spend some time looking at the String class. This does not do what the comment says.
You ever heard of arrays?
Only one instance of the SoftwareSerial class can listen at a time. You are never changing the instance that is listening.
You really need a Mega.
There's a function called myserial.listen() that you should look at.
thanks for the advices ... I'll spend many time on strings an review for the code...
