using Wave Shield for audio output
I have made a series of sensors that when triggered should play a specific audio file. Is there any reason that I would only be able to use three different audio files? I am hoping that I can use five but it seems to only be working with three. Code included below.
#include <SD.h>
#include <FatReader.h>
#include <SdReader.h>
#include <avr/pgmspace.h>
#include "WaveUtil.h"
#include "WaveHC.h"
SdReader card;    // This object holds the information for the card
FatVolume vol;    // This holds the information for the partition on the card
FatReader root;   // This holds the information for the filesystem on the card
FatReader f;      // This holds the information for the file we're play
WaveHC wave;      // This is the only wave (audio) object, since we will only play one at a time
  Serial.begin(9600);  //Setup Serial
  pinMode(14, INPUT);      //Assigns analog pins 0-4 as sensor inputs
  pinMode(15, INPUT);
  pinMode(16, INPUT);
  pinMode(17, INPUT);
  pinMode(18, INPUT);
  pinMode(19, INPUT);
  pinMode(6, OUTPUT);       //Assigns digital pin 6 as output
  pinMode(7, OUTPUT);       //Assigns analog pin 7 as output for motor
  pinMode(8, OUTPUT);       //Assigns digital pin 8 as output for LED cluster 1
  pinMode(9, OUTPUT);       //Assigns digital pin 9 as output for LED cluster 2
  // Set the output pins for the DAC control. This pins are defined in the library
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(10, OUTPUT);
  if (!card.init()) {         //play with 8 MHz spi (default faster!)
    putstring_nl("Card init. failed!");  // Something went wrong, lets print out why
    sdErrorCheck();
    //    while(1);                            // then 'halt' - do nothing!
  // enable optimize read - some cards may timeout. Disable if you're having problems
  //  card.partialBlockRead(true);
  // Now we will look for a FAT partition!
  uint8_t part;
  for (part = 0; part < 5; part++) {     // we have up to 5 slots to look in
    if (vol.init(card, part))
      break;                             // we found one, lets bail
  if (part == 5) {                       // if we ended up not finding one  :(
    putstring_nl("No valid FAT partition!");
    sdErrorCheck();      // Something went wrong, lets print out why
  // Lets tell the user about what we found
  putstring("Using partition ");
  Serial.print(part, DEC);
  putstring(", type is FAT");
  Serial.println(vol.fatType(),DEC);     // FAT16 or FAT32?
  // Try to open the root directory
  if (!root.openRoot(vol)) {
    putstring_nl("Can't open root dir!"); // Something went wrong,
  // Whew! We got past the tough parts.
  putstring_nl("Ready!");
void sdErrorCheck(void)
  if (!card.errorCode())
    putstring("\n\rSD I/O error: ");
  Serial.print(card.errorCode(), HEX);
  putstring(", ");
  Serial.println(card.errorData(), HEX);
  //  while(1);
void playfile(char *name) {
  // see if the wave object is currently doing something
  if (wave.isplaying) {// already playing something, so stop it!
    wave.stop(); // stop it
  // look in the root directory and open the file
  if (!f.open(root, name)) {
    putstring("Couldn't open file ");
    Serial.print(name);
  // OK read the file and turn it into a wave object
  if (!wave.create(f)) {
    putstring_nl("Not a valid WAV");
  // ok time to play! start playback
  wave.play();
void ghost()
  int blinky = 0;
  while(blinky < 40)
    digitalWrite(8,HIGH);
    delay(50);              //set proper delay here for ghost to go to the end
    digitalWrite(8,LOW);
    delay(50);
    blinky++;
  delay(1);
/*void strobe1()
  int blinky = 0;
  while(blinky<12)
    digitalWrite(8,HIGH);    //Blink LED cluster 1 and 2
    digitalWrite(9,HIGH);    //for first half of cat scream
    delay(40);
    digitalWrite(9,LOW);
    delay(40);
    blinky++;
void strobe2()
 int blinky = 0;
  while(blinky < 16)
    delay(80);
    delay(80);
    blinky++;
void strobe4()
 int blinky = 0;
  while(blinky < 80)
    delay(50);
    delay(50);
    blinky++;
  delay(1);
void strobe5()
 int blinky = 0;
  while(blinky < 40)
    delay(40);
    delay(30);
    blinky++;
  delay(1);
// Plays a full file from beginning to end with no pause.
void playcomplete(char *name) {
 //call our helper to find and play this name
  playfile(name);
  while (wave.isplaying) {
// do nothing while its playing
// now its done playing
 if(digitalRead(14) == HIGH)
   // blinky=0;
    playfile("cat.WAV");
      //strobe1();    //try blinking light without function, you are already in a while loop
    delay(40);
    delay(40);
    //blinky++;
     //  putstring_nl("finish sensor 1");
else if(digitalRead(15)==HIGH)
    playfile("help.WAV");
    while(wave.isplaying)
      //strobe2();
else if(digitalRead(16)==HIGH)
  //  digitalWrite(7,HIGH);
    playfile("ghost.WAV");
      //ghost();
 //   digitalWrite(7,LOW);
else if(digitalRead(17)==HIGH)
      //strobe4();
 else if(digitalRead(19)==HIGH)
      //strobe5();
Hi there,
It's difficult to fix this without the original code and the five sound files.
If you still have the problem I'm happy to help, but uploading the sound files and original code are essential. What were the error messages you were receiving (if any?)
Cheers,
Johan
You only call three audio files - two are called twice.
cat.wav
help.wav
ghost.wav
help.wav
ghost.wav
Given that, how do you know all 5 don't work?
Do you have pulldown on inputs so they do not float?
