When compiling this program from IoT with ESP8266: BMP280 and ESP8266 I get no error, here below:
http://www.instructables.com/id/Send-sensor-data-DHT11-BMP180-to-ThingSpeak-with-a/ for use of ESP8266 as controller
https://techtutorialsx.com/2016/05/22/esp8266-connection-to-ds3231-rtc/ for correct use of DS3231
https://github.com/Makuna/Rtc/blob/master/examples/DS3231_Simple/DS3231_Simple.ino for an example by the author of the library
v2: added I2C code for BMP280 from following site:
https://myesp8266.blogspot.be/2016/12/bmp280-and-esp8266.html
v3: exact copy from above link
* Catalin Batrinu bcatalin@gmail.com
* Read temperature and pressure from BMP280
* and send it to thingspeaks.com
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BMP280.h>
#include <ESP8266WiFi.h>
#define BMP_SCK 13
#define BMP_MISO 12
#define BMP_MOSI 11
#define BMP_CS 10
Adafruit_BMP280 bme; // I2C
// replace with your channel’s thingspeak API key,
String apiKey = "YOUR-API-KEY";
const char* ssid = "YOUR-SSID";
const char* password = "YOUR-ROUTER-PASSWORD";
const char* server = "api.thingspeak.com";
WiFiClient client;
* S E T U P
Serial.println(F("BMP280 test"));
if (!bme.begin()) {
Serial.println("Could not find a valid BMP280 sensor, check wiring!");
while (1);
WiFi.begin(ssid, password);
Serial.print("Connecting to ");
Serial.println(ssid);
while (WiFi.status() != WL_CONNECTED)
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
* L O O P
Serial.print("T=");
Serial.print(bme.readTemperature());
Serial.print(" *C");
Serial.print(" P=");
Serial.print(bme.readPressure());
Serial.print(" Pa");
Serial.print(" A= ");
Serial.print(bme.readAltitude(1013.25)); // this should be adjusted to your local forcase
Serial.println(" m");
if (client.connect(server,80)) // "184.106.153.149" or api.thingspeak.com
String postStr = apiKey;
postStr +="&field1=";
postStr += String(bme.readTemperature());
postStr +="&field2=";
postStr += String(bme.readPressure());
postStr += "\r\n\r\n";
client.print("POST /update HTTP/1.1\n");
client.print("Host: api.thingspeak.com\n");
client.print("Connection: close\n");
client.print("X-THINGSPEAKAPIKEY: "+apiKey+"\n");
client.print("Content-Type: application/x-www-form-urlencoded\n");
client.print("Content-Length: ");
client.print(postStr.length());
client.print("\n\n");
client.print(postStr);
client.stop();
//every 20 sec
delay(20000);
When compiling this version below which uses the same libraries, I get a library related error (copy in attachment). What might be wrong here?
As a bonus: why does the compiler often use libraries not stored in my standard Arduino Library folder but uses a folder in C:\Users\Myname\AppData\Local\Arduino15\packages.... ? Annoying because -as far as I know- I have no control over what is stored there..
#include <Wire.h>
#include "Adafruit_HTU21DF.h"
Adafruit_HTU21DF htu = Adafruit_HTU21DF();
#include <RtcDS3231.h>
#include <ESP8266WiFi.h> // ESP8266WiFi.h library
Adafruit_BMP280 bmp; // I2C
RtcDS3231<TwoWire> rtcObject(Wire);
#define SQW_RATE_1K
#define OUTPUT_SQW
byte setOutput = 0;
int setSQWRate = 2;
const char* ssid = "Lieve-router";
const char* password = "xxxxx";
const char* host = "api.thingspeak.com";
const char* writeAPIKey = "xxxxx";
// String apiKey = "YOUR-API-KEY";
WiFiClient client;
unsigned long previousMillis = 1000;
int previousTime = 0;
int currentTime;
const long interval = 1000; //3600000 = elk uur
int pressure; //To store the barometric pressure (Pa)
int temperature;
// float temperature; //To store the temperature (oC)
int altimeter; //To store the altimeter (m) (you can also use it as a float variable)
rtcObject.Begin(); //Starts I2C
RtcDateTime compileDateTime(__DATE__, __TIME__);
// RtcDateTime currentTime = RtcDateTime(16,05,18,21,20,0); //define date and time object
rtcObject.SetDateTime(currentTime); //configure the RTC with object
// Initialize sensor
bmp.begin();
//pinMode(chip_select_pin, OUTPUT);
// Connect to WiFi network
RtcDateTime currentTime = rtcObject.GetDateTime(); //get the time from the RTC
postStr += "&field1=";
postStr += "&field2=";
client.print("X-THINGSPEAKAPIKEY: " + apiKey + "\n");
client.stop();
char str[15]; //declare a string as an array of chars
sprintf(str, "%d/%d/%d %d:%d:%d", //%d allows to print an integer to the string
currentTime.Year(), //get year method
currentTime.Month(), //get month method
currentTime.Day(), //get day method
currentTime.Hour(), //get hour method
currentTime.Minute(), //get minute method
currentTime.Second() //get second method
Serial.println(str); //print the string to the serial port
delay(60000); //60 seconds delay
