Hi, this is the code for the gps on a LILYGO T-SIM7000G TTGO ESP32, so when it comes to the time it is the UTC time and I have no problem with that until it becomes to be my local hour, i have some adjustments and the hour is like instead of saying 23:00 (pm) says -01:00, and the date doesnt update neither, i dont know if someone had a similar problem, i found also another library that supposed to do that but nothing until now, my local time is -5h utc. THANKS
//Define Serial1 Name
#define SIM7000 Serial1
//Define GSM Model
#define TINY_GSM_MODEM_SIM7000
// See all AT commands, if wanted
#define DUMP_AT_COMMANDS
#include <TinyGsmClient.h>
#include <SPI.h>
#include <SD.h>
#include <Ticker.h>
#ifdef DUMP_AT_COMMANDS
#include <StreamDebugger.h>
StreamDebugger debugger(SIM7000, Serial);
TinyGsm modem(debugger);
#else
TinyGsm modem(SIM7000);
#endif
#define UART_BAUD 9600
#define PIN_DTR 25
#define PIN_TX 27
#define PIN_RX 26
#define PWR_PIN 4
#define SD_MISO 2
#define SD_MOSI 15
#define SD_SCLK 14
#define SD_CS 13
#define LED_PIN 12
//Variables
int gnss_run_status = 0;
int fix_status = 0;
int year = 0;
int month = 0;
int day = 0;
int hour = 0;
int minutes = 0;
float secondWithSS = 0;
float lat = 0;
float lon = 0;
float msl_alt = 0;
float speed_over_ground = 0;
float course_over_ground = 0;
bool reserved1 = 0;
int fix_mode = 0;
int hdop = 0;
int pdop = 0;
int vdop = 0;
bool reserved2 = 0;
int gnss_satellites_used = 0;
int gps_satellites_used = 0;
int glonass_satellites_used = 0;
bool reserved3 = 0;
int c_n0_max = 0;
float hpa = 0;
float vpa = 0;
void enableGPS(void)
// Set SIM7000G GPIO4 LOW ,turn on GPS power
// CMD:AT+SGPIO=0,4,1,1
// Only in version 20200415 is there a function to control GPS power
modem.sendAT("+SGPIO=0,4,1,1");
if (modem.waitResponse(10000L) != 1) {
DBG(" SGPIO=0,4,1,1 false ");
modem.enableGPS();
void disableGPS(void)
// Set SIM7000G GPIO4 LOW ,turn off GPS power
// CMD:AT+SGPIO=0,4,1,0
modem.sendAT("+SGPIO=0,4,1,0");
DBG(" SGPIO=0,4,1,0 false ");
modem.disableGPS();
void modemPowerOn()
pinMode(PWR_PIN, OUTPUT);
digitalWrite(PWR_PIN, LOW);
delay(1000); //Datasheet Ton mintues = 1S
digitalWrite(PWR_PIN, HIGH);
void modemPowerOff()
delay(1500); //Datasheet Ton mintues = 1.2S
void modemRestart()
modemPowerOff();
modemPowerOn();
// Set console baud rate
delay(10);
modemPowerOn();
SIM7000.begin(UART_BAUD, SERIAL_8N1, PIN_RX, PIN_TX);
Serial.println("/**********************************************************/");
Serial.println("To initialize the network test, please make sure your GPS");
Serial.println("antenna has been connected to the GPS port on the board.");
Serial.println("/**********************************************************/\n\n");
delay(10000);
if (!modem.testAT()) {
Serial.println("Failed to restart modem, attempting to continue without restarting");
modemRestart();
return;
Serial.println("Start positioning . Make sure to locate outdoors.");
Serial.println("The blue indicator light flashes to indicate positioning.");
enableGPS();
String gps_raw = modem.getGPSraw();
if (gps_raw != "") {
gnss_run_status = splitter(gps_raw, ',', 0).toInt();
fix_status = splitter(gps_raw, ',', 1).toInt();
String date = splitter(gps_raw, ',', 2); //yyyyMMddhhmm ss.sss
year = date.substring(0, 4).toInt();
month = date.substring(4, 6).toInt();
day = date.substring(6, 8).toInt();
hour = date.substring(8, 10).toInt();
minutes = date.substring(10, 12).toInt();
secondWithSS = date.substring(12, 18).toFloat();
lat = splitter(gps_raw, ',', 3).toFloat();//±dd.dddddd
lon = splitter(gps_raw, ',', 4).toFloat();//±ddd.dddddd
msl_alt = splitter(gps_raw, ',', 5).toFloat();//meters
speed_over_ground = splitter(gps_raw, ',', 6).toFloat();//Km/hour
course_over_ground = splitter(gps_raw, ',', 7).toFloat();//degrees
fix_mode = splitter(gps_raw, ',', 8).toInt();
reserved1 = splitter(gps_raw, ',', 9).toInt();
hdop = splitter(gps_raw, ',', 10).toInt();
pdop = splitter(gps_raw, ',', 11).toInt();
vdop = splitter(gps_raw, ',', 12).toInt();
reserved2 = splitter(gps_raw, ',', 13).toInt();
gnss_satellites_used = splitter(gps_raw, ',', 14).toInt();
gps_satellites_used = splitter(gps_raw, ',', 15).toInt();
glonass_satellites_used = splitter(gps_raw, ',', 16).toInt();
reserved3 = splitter(gps_raw, ',', 17).toInt();
c_n0_max = splitter(gps_raw, ',', 18).toInt();//dBHz
hpa = splitter(gps_raw, ',', 19).toFloat();//meters
vpa = splitter(gps_raw, ',', 20).toFloat();//meters
Serial.println("----------------------------------");
Serial.print("GNSS Run Status:"); Serial.println(gnss_run_status);
Serial.print("Fix Status:"); Serial.println(gnss_run_status);
Serial.print("Year:"); Serial.println(year);
Serial.print("Month:"); Serial.println(month);
Serial.print("Day:"); Serial.println(day);
Serial.print("Hour:"); Serial.println(hour);
Serial.print("Minute:"); Serial.println(minutes);
Serial.print("Seconds:"); Serial.println(secondWithSS, 6);
Serial.print("Latitude:"); Serial.println(lat, 6);
Serial.print("Longitude:"); Serial.println(lon, 6);
Serial.print("MSL Altitude:"); Serial.println(msl_alt, 6);
Serial.print("Speed Over Ground:"); Serial.println(speed_over_ground, 6);
Serial.print("Course Over Ground:"); Serial.println(course_over_ground, 6);
Serial.print("Fix Mode:"); Serial.println(fix_mode);
Serial.print("Reserved1:"); Serial.println(reserved1);
Serial.print("HDOP:"); Serial.println(hdop);
Serial.print("PDOP:"); Serial.println(pdop);
Serial.print("VDOP:"); Serial.println(vdop);
Serial.print("Reserved2:"); Serial.println(reserved2);
Serial.print("GNSS Satellites in View:"); Serial.println(gnss_satellites_used);
Serial.print("GPS Satellites Used:"); Serial.println(gps_satellites_used);
Serial.print("GLONASS Satellites used:"); Serial.println(glonass_satellites_used);
Serial.print("Reserved3:"); Serial.println(reserved3);
Serial.print("C/N0 max:"); Serial.println(c_n0_max);
Serial.print("HPA:"); Serial.println(hpa, 6);
Serial.print("VPA:"); Serial.println(vpa, 6);
String splitter(String data, char separator, int index)
int stringData = 0;
String dataPart = "";
for (int i = 0; i < data.length(); i++)
if (data[i] == separator)
stringData++;
else if (stringData == index)
dataPart.concat(data[i]);
else if (stringData > index)
return dataPart;
return dataPart;
