hgycap
December 6, 2022, 2:23am
1
I updated the IDE to 2.0.3.
But still, the error has not fixed.
See the attached file.
Hi @hgycap . Please post your sketch in a reply here as text, not a screenshot. I'll provide instructions:
Select Edit > Copy for Forum (Markdown) from the Arduino IDE menus.
In a forum reply here, click on the post composer field.
Press Ctrl +V .
This will paste the sketch to the post composer.
Click the Reply button to post your reply.
hgycap
December 6, 2022, 6:18am
3
ptillisch:
while(!SerialUSB);
SerialUSB.begin(9600);
SerialUSB.println("한글 출력이 이상해요~");
I am using Arduino Zero with Native USB Port.
Thank you~
Thanks. I think it is the bug that is being tracked here:
opened 02:10PM - 02 Nov 21 UTC
closed 08:01AM - 13 Dec 22 UTC
conclusion: resolved
topic: code
type: imperfection
topic: serial monitor
### Describe the problem
🐛 When Serial Monitor is used to display characters … past the ASCII range printed by a non-native USB board, corruption occurs at various non-fixed positions in the output.
### To reproduce
1. Upload a sketch that prints characters past the ASCII range to serial:
```cpp
Serial.println("ASCII: !\"#$%&'()*+,-./0123456789:;<=>?@ABCDEFGHIJKLMNOPQRSTUVWXYZ[\]^_`abcdefghijklmnopqrstuvwxyz{|}~");
Serial.println("> ASCII: ¡¢£¤¥¦§¨©ª«¬®¯°±²³´µ¶·¸¹º»¼½¾¿ÀÁÂÃÄÅÆÇÈÉÊËÌÍÎÏÐÑÒÓÔÕÖרÙÚÛ");
delay(200);
1. Open Serial Monitor.
🐛 Some of the characters are replaced by `�`:
```text
ASCII: !"#$%&'()*+,-./0123456789:;<=>?@ABCDEFGHIJKLMNOPQRSTUVWXYZ[]^_`abcdefghijklmnopqrstuvwxyz{|}~
> ASCII: ¡��£¤¥¦§¨©ª«¬®¯°±²³´µ¶·¸¹º»��½¾¿ÀÁÂÃÄÅÆÇÈÉÊËÌÍÎÏÐÑÒÓ��ÕÖרÙÚÛ
> ASCII: ¡¢£¤¥¦§¨©ª«¬®¯°±²³´��¶·¸¹º»¼½¾¿ÀÁÂÃÄÅÆÇÈÉÊËÌ��ÎÏÐÑÒÓÔÕÖרÙÚÛ
> ASCII: ¡¢£¤¥¦§¨©ª«¬��¯°±²³´µ¶·¸¹º»¼½¾¿ÀÁÂÃÄÅ��ÇÈÉÊËÌÍÎÏÐÑÒÓÔÕÖרÙÚÛ
> ASCII: ¡¢£¤¥¦��¨©ª«¬®¯°±²³´µ¶·¸¹º»¼½¾¿��ÁÂÃÄÅÆÇÈÉÊËÌÍÎÏÐÑÒÓÔÕÖ×��ÙÚÛ
> ASCII: ¡¢£¤¥¦§¨©ª«¬®¯°±²³´µ¶·¸��º»¼½¾¿ÀÁÂÃÄÅÆÇÈÉÊËÌÍÎÏÐ��ÒÓÔÕÖרÙÚÛ
> ASCII: ¡¢£¤¥¦§¨©ª«¬®¯°±²��´µ¶·¸¹º»¼½¾¿ÀÁÂÃÄÅÆÇÈÉÊ��ÌÍÎÏÐÑÒÓÔÕÖרÙÚÛ
> ASCII: ¡¢£¤¥¦§¨©ª��¬®¯°±²³´µ¶·¸¹º»¼½¾¿ÀÁÂÃ��ÅÆÇÈÉÊËÌÍÎÏÐÑÒÓÔÕÖרÙÚÛ
> ASCII: ¡¢£¤��¦§¨©ª«¬®¯°±²³´µ¶·¸¹º»¼½��¿ÀÁÂÃÄÅÆÇÈÉÊËÌÍÎÏÐÑÒÓÔÕ��רÙÚÛ
> ASCII: ¡¢£¤¥¦§¨©ª«¬®¯°±²³´µ¶��¸¹º»¼½¾¿ÀÁÂÃÄÅÆÇÈÉÊËÌÍÎ��ÐÑÒÓÔÕÖרÙÚÛ
> ASCII: ¡¢£¤¥¦§¨©ª«¬®¯��±²³´µ¶·¸¹º»¼½¾¿ÀÁÂÃÄÅÆÇÈ��ÊËÌÍÎÏÐÑÒÓÔÕÖרÙÚÛ
> ASCII: ¡¢£¤¥¦§¨��ª«¬®¯°±²³´µ¶·¸¹º»¼½¾¿ÀÁ��ÃÄÅÆÇÈÉÊËÌÍÎÏÐÑÒÓÔÕÖרÙ��Û
### Expected behavior
All characters to be printed correctly by Serial Monitor all the time:
### Arduino IDE version
#### Original report
2.0.0-beta.12-nightly.20211028
#### Last verified with
d6a4b0f (with [**serial-monitor** 0.11.0](https://github.com/arduino/serial-monitor/releases/tag/v0.11.0))
### Operating system
Windows
### Operating system version
10
### Additional context
I originally suspected the corruption might be caused by https://github.com/arduino/arduino-ide/issues/375, but this bug persists even though that one has been resolved.
The delay duration has an influence on the position of the corruption and the manifestation is different from one board to another (less corruption on Leonardo and MKR, more on Nano Every).
The issue does not occur when using the Arduino IDE 1.8.19 Serial Monitor, even when the board is running the binary that produced the corrupted output in Arduino IDE 2.x (i.e., it's not related to the sketch having been compiled in Arduino IDE 2.x).
Originally reported at https://forum.arduino.cc/t/serial-monitor-difficulties-with-german-umlauts/870541
Additional reports:
- https://github.com/arduino/arduino-ide/issues/1405
- https://forum.arduino.cc/t/serial-monitor-difficulties-with-german-umlauts/870541/7
- https://forum.arduino.cc/t/serial-read-and-serial-available-are-working-not-as-expected-in-the-code/925823
- https://forum.arduino.cc/t/using-v-2-0-serial-monitor-print/1034093
- https://forum.arduino.cc/t/question-marks-in-serial-monitor/1023531
- https://forum.arduino.cc/t/serial-monitor-detect-interferes-with-sketch-on-promicro/1017659
- https://forum.arduino.cc/t/degree-symbol-on-serial-monitor/1015370
- https://forum.arduino.cc/t/serial-monitor-produces-gibberish/950416/1
- https://forum.arduino.cc/t/serial-monitor-produces-gibberish/950416/15
- https://forum.arduino.cc/t/serial-monitor-issues-with-arduino-due/975247
- https://forum.arduino.cc/t/test-ide-2-0-rc2-the-serial-port-is-garbled/935697
### Issue checklist
- [X] I searched for previous reports in [the issue tracker](https://github.com/arduino/arduino-ide/issues?q=)
- [X] I verified the problem still occurs when using the latest [nightly build](https://www.arduino.cc/en/software#nightly-builds)
- [X] My report contains all necessary details
When I modify the sketch to print the string repeatedly and adjust it to run on my Arduino Mega board:
Serial.println("한글 출력이 이상해요~");
I get that characteristic rotating corruption:
����� ��력��� ��������요~
������ �����이 이��������~
������ �������� ��상������~
���글 ��력��� ��������요~
I don't see that rotation when I run the sketch on my "Arduino Zero (Native USB Port)" board though. On that board I see the same corruption as in your output on every printed line.
