My problem? The ESP32 is very big compared to that DWM1000 module.
I want 3 big anchors (with the anchors I don't care about the size), but I want the tag to be as small as possible. The tag needs a small battery + 5V voltage regulator + microcontroller + charger.
I think it has the microcontroller, voltage regulator and UWB module (everything I need to make it portable), but I'm not sure. (the information is in Chinese, literally)
I open this topic in case someone can help me with a good purchase advice, of some all-in-one module that is very small.
Very small ESP32 board: M5Stack Stamp Pico. This is from the M5Stack docs: 18 * 24 * 4.6mm. It does not breakout all the ESP32 pins so you will have decide if enough pins are available for your application. I ordered from Digikey and Mouser but I have not ordered recently.
Keep in mind that the peak current of the ESP32 is 500mA, average is 200~300mA; the peak current of the DW1000 is 130mA, average is 30~80mA, say 300 mA for both.
AA cells, or an 18650 cell, will last less than 10 hours at that rate.
I still don't know if I can use it with Arduino or not or if it needs a microcontroller, the seller still doesn't respond. He says it only draws 160mA.
I said that I want the module to have a measurement/dimension of 3cm, I did not say that I want to measure the distance of 3cm (I know that the measurement range is 10 cm for the DW1000 UWB modules).
