Variable changed without code
Hi
This simple code bellow displays difference in variables A and B on serial output (IDE 1.0.5, deumillanove).
Variables should be equal and are not changed within code, so I expect that serial output should always write OK.
This is not the case, it writes "not equal ".
Any ideas why ?
regards
Dino
Encoder test
Created by Dino Mrvalj 2014
#include <Wire.h>
int A = 0;
int B = 0;
A = 0;
B = 0;
Wire.begin();
Serial.begin(57600);
Serial.println (" Start ");
  • printout not as expected
    A = B;
    B = A;
if (A=!B) {
Serial.print ("A: "); Serial.print (A); Serial.print (" - B: "); Serial.print (B); Serial.println (" Not equal !?");
else {
Serial.print ("A: "); Serial.print (A); Serial.print (" - B: "); Serial.print (B); Serial.println (" OK ");
Hi, try
!= instead of =!
Tom....... :slight_smile:
No comparison!
You are assigning 'not B' to A
A=!B
B == 0 == FALSE
!B == TRUE
A is assigned TRUE and the if always succeeds.
Try
A == !B
Or like tom said, the more intuitive version:
A != B
