I burned Arduino codes in the controller which runs continuously over time.
The project variable declared as int i= 0; is it advisable. Each time in the void loop() function the controller check the condition of the variable "i" to perform some task.
Observation: The LED matrix starts flickering when the program fails to remember the value of variable "i"
Possible Solution: Declaration int i=0 which stores in Registers, whereas long term program usage can I declare the variable as volatile so that it stores in RAM
There is no difference, registers are just a special area of RAM.
If you have a bug in your code or hardware you'll need to tell us more about you code and hardware.
IE post the code and a diagram of how things are wired up.
if (RTC.read(tm))
setTime(tm.Hour,tm.Minute,tm.Second,tm.Day,tm.Month,tm.Year); // set time to Saturday 8:29:00am Jan 1 2011
If the clock is keeping time, read the time, and adjust the clock so that it is set to the time just read. Add a comment that is completely bogus crap. Why?
Alarm.delay(2); // wait one second between clock display
Do you need to take your shoes off to count above 1? That code does NOT wait one second.
EXECUTE=1;
By convention, all capital letter names are reserved for constants. Constants do not appear on the left of the = sign except when initially declared and initialized.
if (Time_now>=820 && Time_now<1814){
Morning_Reminder_1();
Why are you explicitly calling your alarm callback functions?
if(SET==1){
m.init();
m.setIntensity(1);
SET = false;
Whoops! That's probably removed some vital part of the program. The original comment was more about the coding style. ALLCAPS is usually used to denote a constant.
The solution is to rename EXECUTE everywhere in the program to something else. Choose something more descriptive like ExecuteTheDaleks. There's no limit on how may letters you can use in a variable name although more than 30 gets difficult to read and to type.
