Hello, and thank you for your time. I am using a variable to record the last state read from a switch before it was turned off by the if statement. I am using Serial.print to check the state of the variable for changes and also to Serial.print a digitalRead of the switch to see if there are changes. The digitalRead of the switch changes from 0 to 1 as it is supposed to, but the variable doesn't change from 0 to 1 like it should. Why is the variable not changing as I think it should? Thank you for your help
//////////////////////////// Skimmer Status and Display global
const int SkimmerFullLed (4); // the pin number of the Skimmer Status led pin
const int SkimmerFullFloat (3); // the pin number of the Floatswich pin
const int SkimmerOnButton (2); // the pin number of the pushbutton pin
const int SkimmerRelay (5); // the pin number of the skimmer relay pin
const int ScreenDelayButton (20); // the pin number of the screen delay button pin
// variables will change:
int SkimmerFloatState = 0; // variable for reading the skimmer float state
int SkimmerFullLedState = 0;
int SkimmerOnButtonState = 0;
int ScreenDelayButtonState = 0;
int SkimmerFullMsgState = 0;
void setup() //////////////////////// Setup ///////////////////////////////////////////////////////////////////////////////////////////
Serial.begin(9600); //////////////// Initialize Serial communications
lcd.begin(20, 4); //////////////// Initialize the 2004 LCD
pinMode(SkimmerFullLed, OUTPUT); // initialize the LED pin as an output
pinMode(SkimmerFullFloat, INPUT_PULLUP); // initialize the Float Switch pin as an input
pinMode(SkimmerOnButton, INPUT_PULLUP); // initialize the Skimmer on Button pin as an input
pinMode(SkimmerRelay, OUTPUT); // initialize the Skimmer relay pin as an output
pinMode(ScreenDelayButton, INPUT_PULLUP); // initialize the screen delay button as an input
void DisplayTimeTemp() ////////////Display time and Water temperatures function Setup
lcd.clear(); /////////////////Display Time and Date
lcd.setCursor(0, 0);
lcd.print(rtc.getDOWStr());
lcd.print(" ");
lcd.print(rtc.getDateStr());
lcd.setCursor(0, 1);
lcd.print(rtc.getTimeStr());
lcd.setCursor(9, 1);
lcd.print("RTC ");
lcd.print(rtc.getTemp());
lcd.print(" C");
V0 = analogRead(ThermistorTankPin0); ////////////////// Read tank thermistor
R2 = R1 * (1023.0 / (float)V0 - 1.0);
logR2 = log(R2);
Temp = (1.0 / (c1 + c2 * logR2 + c3 * logR2 * logR2 * logR2));
Temp = Temp - 273.15;
//Tenp = (Temp * 9.0)/ 5.0 + 32.0;
lcd.setCursor(0, 2); // Set the cursor at the 4th column and 1st row ///////// Display tank water tempreture
lcd.print("Tank Temp = ");
lcd.print(Temp);
lcd.print(" C");
V1 = analogRead(ThermistorSumpPin1); ////////////////// Read Sump thermistor
R2 = R1 * (1023.0 / (float)V1 - 1.0);
logR2 = log(R2);
//Temp = (Temp * 9.0)/ 5.0 + 32.0; /Convert celsius to fahrenheit
lcd.setCursor(0, 3); // Set the cursor at the 4th column and 1st row ///////// Display tank water temperature
lcd.print("Sump Temp = ");
lcd.print(Temp);
lcd.print(" C");
void loop() //////////////////////////////// Loop ////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
Serial.println("");
Serial.println("SkimmerFloatState");
Serial.println(SkimmerFloatState);
Serial.println("Digital read float ");
Serial.println(digitalRead(SkimmerFullFloat));
Serial.println("");
DisplayTimeTemp();
if (SkimmerFloatState == 0) // Float state starting point it should do this every time until the skimmer is seen full
digitalRead(SkimmerFullFloat); // read the state of the Skimmer full float switch value:
if (SkimmerFullFloat == LOW) // if skimmer is full
SkimmerFloatState = 1; //Set skimmer float state to 1 for last read was full
digitalRead(SkimmerOnButton); // read the state of the Skimmer reset button value:
if (SkimmerFullMsgState == 1)
SkimmerFullMsg();
ScreenDelayButtonState = digitalRead(ScreenDelayButton); // read the state of the Skimmer button
if (ScreenDelayButtonState = LOW) //If screen delay button is pressed delay 5 seconds
delay(5000);
if (SkimmerFloatState == 1) //If Skimmer is full
digitalWrite(SkimmerRelay, HIGH); ////ACTIVE LOW turn skimmer off
analogWrite(SkimmerFullLed, 25); ////turn skimmer full led on
lcd.clear();
SkimmerFullMsg(); ////Display Skimmer Full Message
if (SkimmerFloatState == 1 && SkimmerOnButtonState == LOW) //If skimmer is empty, and skimmer on button is pressed
digitalWrite(SkimmerRelay, LOW); /////ACTIVE LOW turn on relay
digitalWrite(SkimmerFullLed, LOW); ////Turn off skimmer full led
SkimmerFullMsgState = 0; ////Turn off SkimmerFullMsg
SkimmerFloatState = 0; ////Reset skimmer float to zero
lcd.clear();
This is the function for the skimmer full Message if it is important
void SkimmerFullMsg() ///////// Function for Display the skimmer full Message Setup
lcd.clear();
lcd.setCursor(0, 0); ////set cursor on the start of the 1 row
lcd.print(" Skimmer Full"); ////write on the Lcd
lcd.print("Empty Clean, Replace");
lcd.print(" Then Press the");
lcd.print(" Button to Restart");
SkimmerFullMsgState = 1;
delay(2000);
You gave "SkimmerFullFloat" the value 3.
LOW has the value zero.
They are never, ever going to be equal.
So instead of declaring 3 as the pin I am using for the "SkimmerFullFloat", I am actually giving it a constant value of 3? What is the correct way to declare pin usages? The strange part is, it is seeing the "SkimmerFullFloat" on pin (3) because When I digitalRead it it changes from 0 - 1.
What would you try changing? Thank you for your help.
TheMemberFormerlyKnownAsAWOL:
You could try a digitalRead
The digitalRead confirms the switch is found on pin 3 and is giving the correct value for the state that the switch is in, but it does not change the variable like it is told to in this line:
if (SkimmerFloatState == 0) // Float state starting point it should do this every time until theskimmer is seen full
According to my Serial.println("SkimmerFloatState"); it is always 0 so it should be doing this every loop until it reads 1.
kaylebbccan814:
I see what you mean, when I do a Serial.println(SkimmerFullFloat); it returns a 3 even though Serial.println(digitalRead(SkimmerFullFloat)); returned a 1 for closed, How do I fix this?
Serial.println("");
Serial.println("SkimmerFloatState"); ///////stays 0
Serial.println(digitalRead(SkimmerFullFloat)); ////changes like it should from 1 to 0
Serial.println("");
Serial.println(SkimmerFullFloat); //////////// stays at 3
Serial.println("");
You seemed to be very confused about pin numbers and pin states. For example, the following code makes no sense:
If you want the SkimmerFloatState to reflect whether the skimmer was full you could do something like this:
A **digitalRead()** that is not assigned to a variable is useless.
Yes , I am... I am trying to learn but always get stuck, thank you for your help, that makes more sense to me now, I will try changing some things now and see how I make out, please bear with me, I might not be that smart but I am determined to learn. Thanks again
Thank you ToddL1962, I appreciate you helping me understand pin states vs. pin numbers. Your example made sense to me, and I now have a better understanding of what I was actually asking in the line:
SkimmerFullFloat will always be 3 as that is what I declared it as by the line:
But if I digital Read it and compare the result, then I can change a variable accordingly.
if (SkimmerFloatState == 0 && (digitalRead(SkimmerFullFloat) == LOW)) // Float state starting point it should do this every time until theskimmer is seen full
lcd.clear();
SkimmerFullMsg();
if (SkimmerFloatState == 1 && (digitalRead(SkimmerOnButton) == LOW)) //If skimmer is empty, and skimmer on button is pressed
lcd.clear();
if (digitalRead(ScreenDelayButton) == LOW)
delay(5000);
Anyhow I got it, and it works the way I had intended. Thank you all for your patience and help. Thanks to all of you guys and the wealth of knowledge in this community, I am learning ,and creating more every day. Hopefully one day I can actually give back and help others as well. Much appreciated all...
