variable or field 'name' declared void Help please
Hello, I am trying to insert a web server taken from here (part 16) into my surveillance code and am getting this error. I then reduced the code to the minimal still causing the same error message
int a=0;
#include <Ethernet.h>
void setup(){}
void loop() {}
void XML_response(EthernetClient cl){}
error message: variable or field 'XML_response' declared void
Could someone show me what I am doing wrong?
Thanks in advance for your help
It compiles for me. 1.6.5
#include <SPI.h>
int a = 0;
void setup(){}
void loop() {}
IDE 1.6.5
int a=0;
#include <SPI.h>
void setup(){}
void loop() {}
ajeter:6: error: variable or field 'XML_response' declared void
ajeter:6: error: 'EthernetClient' was not declared in this scope
ajeter.ino:10:6: warning: unused parameter 'cl' [-Wunused-parameter]
Compiled for me under 1.6.6.
I wouldn't normally put anything before my #includes.
YMMV.
What version IDE are you using?
@aarg: Post #3 suggests 1.6.5
Is there more code? Please verify that you didn't miss anything when you posted.
AWOL:
YMMV.
That is necessary if there are #ifdef statements used. The IDE has some strange ideas where to put the #include statements it adds. Defining a useless variable as the first line of the file gives the IDE a known insertion point.
AWOL:
YMMV.
w/o the assignment it compiles with warnings only
yes, code compiles if no assignment before the #include (!)
Before the merge the code compiled wo problems dispite early assignments. After the merge of the server it was rejected at the function déclaration
