Variable update in SQL database
Hi there,
I amtrying to upload data into an SQL database. The database is located in a domain server and I my arduino establishes well communication trough GET command and php seems to work ok also. The problem I have is that variables show 0 as result in the column. I can only write a value if I put it directly in the server .php document, as shown in the example... What I am doing wrong? I tried several variations to the .php, where I think the problem is...
PHP file:
<?php
    // PhpConsulta.php
    // Importamos la configuración
$servername = "localhost";
$database = "databasename";
$username = "username";
$password = "password";
// Create connection
$con = mysqli_connect($servername, $username, $password, $database);
// Check connection
if (!$con) {
      die("Connection failed: " . mysqli_connect_error());
echo "Connected successfully";
    // Leemos los valores que nos llegan por GET
    $x=$_GET['ID'];
    $y=$_GET['TEMP'];
    $Z=$_GET['HR'];
    // Esta es la instrucción para insertar los valores
    $query = "INSERT INTO tablename (ID, TEMP, HR) VALUES (ID, '22.5','".$z."')";
    // Ejecutamos la instrucción
    mysqli_query($con, $query);
    mysqli_close($con);
Arduino code:
include "DHT.h"
#include <SPI.h>
#include <WiFiNINA.h>
#include "arduino_secrets.h"
#define DHTPIN 2     // what digital pin we're connected to
#define DHTTYPE DHT11   // DHT 11
DHT dht(DHTPIN, DHTTYPE);
//conexión WIFI
char ssid[] = SECRET_SSID;             //  your network SSID (name) between the " "
char pass[] = SECRET_PASS;             // your network password between the " "
int status = WL_IDLE_STATUS;
WiFiClient client;
// server address:
char server[] = "servername.com";
unsigned long lastConnectionTime = 0;            // last time you connected to the server, in milliseconds
const unsigned long postingInterval = 10L * 1000L; // delay between updates, in milliseconds
dht.begin();
while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // check for the WiFi module:
  if (WiFi.status() == WL_NO_MODULE) {
    Serial.println("Communication with WiFi module failed!");
    // don't continue
    while (true);
  String fv = WiFi.firmwareVersion();
  if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
    Serial.println("Please upgrade the firmware");
  // attempt to connect to Wifi network:
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
    status = WiFi.begin(ssid, pass);
    // wait 10 seconds for connection:
// you're connected now, so print out the status:
  printWifiStatus();
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t) || isnan(f)) {
    Serial.println("Failed to read from DHT sensor!");
    return;
Serial.print("Temperatura: ");
Serial.print(t);
Serial.println("ºC");
Serial.print("Humedad Relativa: ");
Serial.print(h);
Serial.println("%");
  // if there's incoming data from the net connection.
  // send it out the serial port.  This is for debugging
  // purposes only:
  // while (client.available()) {
  //  char c = client.read();
  //  Serial.write(c);
// if ten seconds have passed since your last connection,
  // then connect again and send data:
  if (millis() - lastConnectionTime > postingInterval) {
    httpRequest();
// this method makes a HTTP connection to the server:
void httpRequest() {
  // close any connection before send a new request.
  // This will free the socket on the Nina module
  //client.stop();
  // if there's a successful connection:
  if (client.connect(server, 80)) {
    Serial.println("connecting...");
    // send the HTTP PUT request:
float ID='EJEMPLO';
float HR;
float TEMP;
int $Z;
int $y;
    client.print(HR);
    client.print(TEMP);
    client.println("GET /PhpConsulta.php?TEMP=$y HTTP/1.1");
    client.println("Host: www.servername.com");
    client.println("User-Agent: ArduinoWiFi/1.1");
    client.println();
    client.println("Connection: close");
    client.println();
    // note the time that the connection was made:
    lastConnectionTime = millis();
    // if you couldn't make a connection:
    Serial.println("connection failed");
client.stop();
void printWifiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your board's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
Database looks like this:
type or paste code here
Your Arduino code doesn't look valid enough to compile.
@wildbill is correct, that cannot be the code you uploaded to Arduino. Please find the code you uploaded, click Auto Format, then post that.
Also please post what you see in serial monitor. Use code tags for that also.
This is the compiling result:
C:\LOCAL\ARDUINO\SQLQUASAR\Sensor_DHT11_SQLQUASAR3\Sensor_DHT11_SQLQUASAR2\Sensor_DHT11_SQLQUASAR2.ino:187:10: warning: character constant too long for its type
float ID='EJEMPLO';
C:\LOCAL\ARDUINO\SQLQUASAR\Sensor_DHT11_SQLQUASAR3\Sensor_DHT11_SQLQUASAR2\Sensor_DHT11_SQLQUASAR2.ino:188:15: warning: character constant too long for its type
float CLIENTE='CLIENTE';
C:\LOCAL\ARDUINO\SQLQUASAR\Sensor_DHT11_SQLQUASAR3\Sensor_DHT11_SQLQUASAR2\Sensor_DHT11_SQLQUASAR2.ino:189:18: warning: character constant too long for its type
float GENERACION='GENERACION';
Sketch uses 30736 bytes (11%) of program storage space. Maximum is 262144 bytes.
Global variables use 2580 bytes (7%) of dynamic memory, leaving 30188 bytes for local variables. Maximum is 32768 bytes.
Similarly, those errors don't tie back to the code.
You are right, I confused projects. Will look for the good one (without errors) and upload them back. Sorry about that.
Here we go. After revising the correct files, I truly believe the problem is in the php file..
php:
<?php
$database = "myudatabase";
$username = "myusername";
$password = "mypwd";
$conn = mysqli_connect($servername, $username, $password, $database);
// Check connection
if (!$conn) {
$sql = "INSERT INTO MY_TABLE VALUES ($_GET["ID"],$_GET["TEMP"],$_GET["HR"])";
$ID=$_get['ID'];
$TEMP=$_get['TEMP'];
$HR=$_get['HR'];
if (mysqli_query($conn, $sql)) {
      echo "New record created successfully";
      echo "Error: " . $sql . "<br>" . mysqli_error($conn);
mysqli_close($conn);
Arduino:
#include "DHT.h"
#include <SPI.h>
//conexión WIFI
WiFiClient client;
// server address:
char server[] = "mydomain.com";
dht.begin();
while (!Serial) {   // wait for serial port to connect. Needed for native USB port only
    Serial.println("PUERTO SERIAL OK");
  if (WiFi.status() == WL_NO_MODULE) {    // check for the WiFi module:
    Serial.println("No hay comunicación con el módulo WiFi");
   while (true); // don't continue
  Serial.println("Por favor actualice firmware");
  while (status != WL_CONNECTED) {  // attempt to connect to Wifi network:
    Serial.print("Conectando con SSID: ");
    Serial.println(ssid);  // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
    delay(1000);  // wait for connection
printWifiStatus();
  // Reading temperature or humidity takes about 250 milliseconds!
  // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
  float h = dht.readHumidity();
  // Read temperature as Celsius (the default)
  float t = dht.readTemperature();
if (isnan(h) || isnan(t)) {
    return;
Serial.print(t);
Serial.print(h);
    httpRequest();
  // purposes only:
   Serial.write(c);
  client.stop();
// send the HTTP GET request:
float TEMP = t;
float HR = h;
    client.println("GET /PhpConsulta.php?TEMP= HTTP/1.1");
    client.println("Host: www.mydomain.com");
    client.println();
    delay(300);
    else {
    printWifiStatus();
  Serial.println(ip);
  Serial.print(rssi);
Why not test that theory? You can easily do that from your browser by entering an address & parameters:
http://www.mydomain.com/PhpConsulta.php?ID=123&TEMP=456&HR=789
This part looks incorrect:
$ID=$_get['ID'];
$HR=$_get['HR'];
I am not sure if the first line will format the SQL string you wanted. But I am certain that it is pointless to get the 3 parameters and assign them to variables and then never use them!
Try this:
$ID=$_get['ID'];
$HR=$_get['HR'];
$sql = "INSERT INTO MY_TABLE VALUES ($ID,$TEMP,$HR)";
Once you have your php corrected and tested from your browser, you can then look at the errors in your Arduino code. For example:
float TEMP = t;
float HR = h;
    client.println();
In this code, you read the temperature and humidity but then you do not include those values in the get request that is sent.
It should be something like:
    client.print("GET /PhpConsulta.php?ID=123&TEMP=");
    client.print(t);
    client.print("&HR=");
    client.print(h);
    client.println(" HTTP/1.1");
    client.println();
Please click Auto Format in the IDE before you post your code each time, to make it easier to read.
Thank you!
My problem still with php file..
This code works but column TEMP results are always zero
ID increases correctly.
I have reduced to one column for simplicity purposes
<?php
$database = "mydatabase";
// Check connection
if (!$conn) {"Conexion OK";
$_GET['ID'];
$_GET['TEMP'];
$sql = "INSERT INTO mytable (ID, TEMP) VALUES(ID, TEMP)";
Pay close attention to what you put in your code compared to the examples of code given to you. With PHP, like C++ and every other language, small things are important. Compare that line from your code to my suggestion from the earlier post. There is a small but important difference.
How is the table mytable defined? Is the ID column defined to be automatically populated with an increasing row identifier or something?
Yes, ID column is defined to be automatically populated with an increasing row identifier.
I also tried
$sql = "INSERT INTO PV_QUASAR1 VALUES ($ID,$t)";
but then the message return is:
?> Connected successfullyError: INSERT MY_TABLE VALUES (,)
You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ')' at line 1
Then tried:
$sql = "INSERT INTO PV_QUASAR1 VALUES ('$ID','$t')";
no error message when:
put into the browser:
'https://www.mydomain.com/PhpConsulta.php?TEMP=456'
But still TEMP value does not update
Sorry I put:
$sql = "INSERT INTO PV_QUASAR1 VALUES ('$ID','$TEMP')";
In that case, should your INSERT statement be inserting any value for ID?
You have lost the column names of the columns you are giving values for. They were present in your earlier posts.
Post the definition of your table.
Maybe my code here will give you some ideas.
Finally, after all your help and many 'night' hours... It WORKS!! Thank you! Had problems with variables definition and some syntax... bellow php and arduino:
php: PhpConsulta.php
<?php
$password = "mypassword";
// Check connection
if (!$conn) {
$ID=$_GET['ID'];
$t=$_GET['t'];
$h=$_GET['h'];
$sql = "INSERT INTO mytable (ID, t, h) VALUES ('$ID','$t','$h')";
arduino:
#include "DHT.h"
#include <SPI.h>
//conexión WIFI
WiFiClient client;
char server[] = "mydomain.com"; // server address:
  dht.begin();
  while (!Serial) {
    Serial.println("Communication with WiFi module failed!"); // don't continue
    while (true);
    // wait for connection:
  printWifiStatus();
  float HR = h;
    return;
  Serial.print(t);
  Serial.print(h);
  delay(1000); //wait
  // if 10 seconds have passed since your last connection,
    httpRequest();
  // purposes only:
    Serial.write(c);
  client.stop();
    float temp = dht.readTemperature();
    float hum = dht.readHumidity();
    int ID = (0);
    float t = (temp);
    float h = (hum);
    client.print("GET /PhpConsulta.php?ID=");
    client.print(ID);
    client.print("&t=");
    client.print(t);
    client.print("&h=");
    client.print(h);
    client.println();
    client.println();
  Serial.println(ip);
  Serial.print(rssi);
