Variable Update with Button - Bug or mistake
I don't know if it is bug aerror in my script. I have push button on PIN2 with a capacitor and a pull-up resistor.
When the button is pressed In want to switch variable "sequenceNo" between 1 and 2. What is weird, is that in my debug output I get this.
Button Pressed
New Sequence No: 21
Button Pressed
New Sequence No: 21
Script:
//Parameters for sequence No:
const int button = 2;  // Select button on pin 2
int switchState;
int sequenceNo = 1; // Default sequence
// Sequence Button Setup
pinMode(button, INPUT);
 getSequenceNo();
// Functions for Led Strips
void getSequenceNo() {
 switchState = digitalRead(button);
 if (switchState == LOW) {
  Serial.println ("Button Pressed");
  if (sequenceNo == 1) {
    sequenceNo = 2;
  else {
    sequenceNo == 1;
  Serial.print ("New Sequence No: ");
  Serial.println (Serial.print(sequenceNo));
Thanks.
Just have
Serial.println (sequenceNo);
What’s this ?
else {
  sequenceNo == 1;
should be
else {
  sequenceNo = 1;
and
Serial.println(Serial.print(sequenceNo));
should be
Serial.println(sequenceNo);
Thanks for helping. It solved my problem.
Pascal
