Variables defination problem (again) ;-)
The following sketch (base is an example from Seeed_Arduino_CAN-2.3.3 library, slightly modified by me) returns a 8 Byte buffer from CAN-Bus dialog.
On canId "849" the buf[1] and buf[2] bytes holds the interesting data (chars), where buf[2] is the highbyte and buf[1] the lowbyte.
I can read this and view it via SERIAL_PORT_MONITOR.print without any problems.
But when I try to display the calculated Word (sped) via SERIAL_PORT_MONITOR.print,
I get only correct values if the value of buf[2] < 80hex.
Above that, I get negative values although I've defined usigned variables.
What I'm doing wrong ?
Please help.
#include <SPI.h>
#define CAN_2515
const int SPI_CS_PIN = 10;
const int CAN_INT_PIN = 2;
#include "mcp2515_can.h"
mcp2515_can CAN(SPI_CS_PIN); // Set CS pin
int i;
byte hiv2;
byte hiv3;
unsigned long sped;
int CanBusSwitch = 8;
    SERIAL_PORT_MONITOR.begin(9600);
    while (CAN_OK != CAN.begin(CAN_100KBPS)) {             // init can bus : baudrate = 500k
        SERIAL_PORT_MONITOR.println("CAN init fail, retry...");
        delay(100);
    SERIAL_PORT_MONITOR.println("CAN init ok!");
    pinMode(CanBusSwitch, OUTPUT);            // Definiere Ausgang für CanBusSwitch (Umschaltung Zusatzinfos über Radio-Text-Display)
    digitalWrite (CanBusSwitch, HIGH);         // Schalte Ausgang für CanBusSwitch aktiv
    unsigned char len = 0;
    unsigned char buf[8];
    if (CAN_MSGAVAIL == CAN.checkReceive()) {         // check if data coming
        CAN.readMsgBuf(&len, buf);    // read data,  len: data length, buf: data buf
        unsigned long canId = CAN.getCanId();
        if (canId == 849)
            hiv2 = buf[2];
            hiv3 = buf[1];
            sped = (hiv2 * 256) + hiv3;
            SERIAL_PORT_MONITOR.print(hiv2);
            SERIAL_PORT_MONITOR.print("\t");
            SERIAL_PORT_MONITOR.print(hiv3);
            SERIAL_PORT_MONITOR.print(sped);
        SERIAL_PORT_MONITOR.println();
//END FILE
The expression will be promoted and evaluated as integer data type.
Try
          sped = (((unsigned int) hiv2)<<8) + hiv3;
Works, thank you, but I dont understand why (it's integer, when I've declared it in another type)
In C/C++, the variable type on the left side of the "=" has no effect on how the right side of the expression is evaluated.
The presence of the 256, which cannot be expressed as a byte, forces the expression to be promoted to integer for evaluation.
