I am trying to use a variable with a decimal place, but can't.
The "float" variable option is the only option that allows me to use a decimal, but it's big (use 4 bytes) and isn't always exact (Source: http://arduino.cc/en/Reference/Float)
I would expect use a decimal place with "word" but can't either.
Can anyone tell me if it's at all possible to use a decimal in a variable, reliably?
Nothing we can do about unreasonable expectations. word is some crap invented by the idiots in Redmond to describe an int.
Of course. That's what floats are for. Well, besides parades.
It's 4 bytes, yes. It has 6 to 7 digits of accuracy. Isn't the sufficient? Can you tell the difference in temperature between 27.003 and 27.0031 degrees?
You can't. Unless you create your own fixed decimal type, you are stuck with two options:
Use float: Accuracy "and isn't always exact " is usually OK in practice.
Use an integer and treat the last two (or whatever) digits as decimals. i.e., x = 102 would really be 1.02.
The only time it is an issue is when you print it. You will need to create a special "PrintMyVariable" function that adds the decimal point and return a string to be printed.
If you want more compact representation of real numbers you could use fixed point or 16-bit float formats. There is no hardware support for these per se, though fixed point operates with standard integer math and you just convert to/from regular float from it. So if you have say 10.6 fixed point value (i.e. 16 bits) it means you allocate 10 bits for integer and 6 bits for decimal part and store the entire thing in one 16-bit value. In 10.6 case your integer has 2^10 values and decimal part 2^6 values so int range is [-512, 511] (or [0, 1023] for unsigned) and decimal precision of 1/(2^6)=~0.0156. So based on your requirements you can allocate enough bits for int & decimal parts. 16-bit float is more tricky but it can handle wider range of values with varying precision just like regural floats.
Thanx, that's probably going to be the safest then. But, how do I add the decimal point after the first character?
That's going to depend on how you're displaying it. If you're sending it to Serial.print(), you can do some quick math:
int x;
x = 102; // Really 1.02, but we're keeping it stored as x * 100 so it fits in an int and doesn't lose decimal places
Serial.print(x / 100);
Serial.print(".");
if (x % 100 < 10)
Serial.print("0");
Serial.println(x % 100);
