In an idle moment I have been playing around with "one line" waveform generation function (led blink etc.) such as:
const uint32_t mask = 0x1000 | 0x3FF ;
digitalWrite( LED1, ( ( ( millis() & 0x1FFF ) | 0x3FF ) == mask ? HIGH : LOW ) ) ;
digitalWrite( LED2, millis() % 4000 < 1500 ? HIGH : LOW ) ;
digitalWrite( LED3, millis() % 4096 < 1500 ? HIGH : LOW ) ; // %power of 2
digitalWrite( LED4, millis() & 0x200 ? HIGH : LOW ) ;
to see how these perform. There may be other and better ones which I have not seen/thought of. The initial conclusion is that the one with the modulus arithmetic is the easiest but quite inefficient unless the divisor is a power of 2.
If anyone is interested in playing with it, it is here: https://wokwi.com/projects/455336479619627009
and the code:
Click here to see the code
Testing various methods of using the millis() timer in the loop() in this example format:
// calculation for test 1
0000'0000'0000'0000'0000'0000'0000'0000 // 0
0000'0000'0000'0000'0001'0000'0000'0000 // 0x1000 (4096) ~4 seconds (power of 2)
0000'0000'0000'0000'0001'1111'1111'1111 // 0x1FFF
0000'0000'0000'0000'0000'0000'0011'1111 // 0x3F (31) 63ms
0000'0000'0000'0000'0000'0010'0000'0000 // 0x200 (512) (power of 2)
Serial.println("Starting. . . ") ;
pinMode( LED_BUILTIN, OUTPUT ) ;
uint32_t start ;
uint16_t microTimer ;
uint16_t microTimerElapsed ;
volatile bool singleExecution ;
cli() ;
TCCR1A = 0x00;
TCCR1B = (1 << CS10); // No prescaler
TCNT1 = 0x0000;
sei() ;
Serial.println("Test 1: period = ~4 seconds, On time = 63ms") ;
start = millis() ;
while ( millis() - start < 10000 ) {
digitalWrite( LED_BUILTIN, ( ( ( millis() & 0x1FFF ) | 0x3FF ) == mask ? HIGH : LOW ) ) ;
// time of single execution
microTimer = TCNT1 ;
singleExecution = ( ( ( millis() & 0x1FFF ) | 0x3FF ) == mask ? HIGH : LOW ) ;
microTimerElapsed = TCNT1 - microTimer ;
Serial.print( "calculation time single execution (ticks 62.5ns ) = " ) ;
Serial.println( microTimerElapsed ) ;
Serial.println() ;
Serial.println("Test 2: period = 4 seconds , On time = 1.5s") ;
start = millis() ;
digitalWrite( LED_BUILTIN, millis() % 4000 < 1500 ? HIGH : LOW ) ;
singleExecution = millis() % 4000 < 1500 ? HIGH : LOW ;
Serial.println() ;
Serial.println("Test 3: period = ~4 seconds (% power of 2) , On time = 1.5s") ;
start = millis() ;
digitalWrite( LED_BUILTIN, millis() % 4096 < 1500 ? HIGH : LOW ) ;
singleExecution = millis() % 4096 < 1500 ? HIGH : LOW ;
Serial.println() ;
Serial.println("Test 4: period = 1024ms, On time = 512ms") ;
start = millis() ;
digitalWrite( LED_BUILTIN, millis() & 0x200 ? HIGH : LOW ) ;
singleExecution = millis() & 0x200 ? HIGH : LOW ;
Serial.println() ;
Serial.println("End of test") ;
