Hi there,
I am new to Arduino and have one of those problems where you know there is a simple solution but a few attempts have not worked..!
I have a code which works perfectly for controlling the brightness of 3 LEDs from one LDR, and all I want to do is the opposite, so that when the LDR is covered, the LEDs get darker instead of brighter.
Have tried a couple of things but nothing is working properly, so thought I would ask for some help, if anyone could point me in the right direction I would be very grateful!
Thank you in advance,
Here is my code:
//analog in - values from light sensor
//variables
#define ledpinA 10 //PWM pin
#define ledpinB 11
#define ledpinC 9
#define sensor 1
int val=0;
int bright=0;
//SETUP
pinMode(ledpinA,OUTPUT);
pinMode(ledpinB,OUTPUT);
pinMode(ledpinC,OUTPUT);
//LOOP
val=analogRead(sensor);
Serial.println(val);
//values up to 917
val=constrain(val,0,917);
bright=map(val,0,917,0,255);
analogWrite(ledpinA,bright);
analogWrite(ledpinB,bright);
analogWrite(ledpinC,bright);
delay(100);
