Hi everyone,
I got Arduino UNO and WIFI shield this week
Now i use 1.0.6 as my IDE
When i started program, i tried basic example about serial and WIFi, they all work.
But when i wants to make them together and add some new in it. problem come,and very strange , i don't why .
My program would search all avaliable wifi networks and try to connect the "PreferSSID".
and then show a menu to do different function.
Here is my Code:
#include <SPI.h>
#include <WiFi.h>
#include<WiFiudp.h>
const byte BUF_SIZE=64;
const unsigned long SERIAL_RATE=9600;
const char PreferSSID[] = "MySSID";
const char PreferSSIDPSW[] = "MYSSIDPSW";
char CurrentSSID[BUF_SIZE / 2 ];
char CurrentPSW[BUF_SIZE / 2 ];
char bufFromSerial[BUF_SIZE];
char lenOfBuf=0;
char tem1[BUF_SIZE];
char tem1Len=0;
char tem2[BUF_SIZE];
char tem2Len=0;
int WIFIstatus = WL_IDLE_STATUS;
char numSsid;
IPAddress ServerIP;
WiFiUDP Udp;
void SearchWIFINetwork()
Serial.println("Scanning available networks...");
numSsid= WiFi.scanNetworks();
if (numSsid == -1)
Serial.println("not wifi SSID is found");
listNetworks(numSsid);
connWIFI((char*)PreferSSID,(char *)PreferSSIDPSW);
void printMacAddress()
// the MAC address of your Wifi shield
byte mac[6];
// print your MAC address:
WiFi.macAddress(mac);
Serial.print("MAC: ");
Serial.print(mac[5], HEX);
Serial.print(":");
Serial.print(mac[4], HEX);
Serial.print(":");
Serial.print(mac[3], HEX);
Serial.print(":");
Serial.print(mac[2], HEX);
Serial.print(":");
Serial.print(mac[1], HEX);
Serial.print(":");
Serial.println(mac[0], HEX);
void listNetworks(int numSsid) {
Serial.println("========Avaliable Wifi networks:========");
// print the list of networks seen:
Serial.print("number of available networks:");
Serial.println(numSsid);
for (int thisNet = 0; thisNet < numSsid; thisNet++)
Serial.print(thisNet);
Serial.print(") ");
Serial.print(WiFi.SSID(thisNet));
Serial.print("\tSignal: ");
Serial.print(WiFi.RSSI(thisNet));
Serial.print(" dBm");
Serial.print("\tEncryption: ");
printEncryptionType(WiFi.encryptionType(thisNet));
void printEncryptionType(int thisType) {
// read the encryption type and print out the name:
switch (thisType) {
case ENC_TYPE_WEP:
Serial.println("WEP");
case ENC_TYPE_TKIP:
Serial.println("WPA");
case ENC_TYPE_CCMP:
Serial.println("WPA2");
case ENC_TYPE_NONE:
Serial.println("None");
case ENC_TYPE_AUTO:
Serial.println("Auto");
Serial.begin(SERIAL_RATE);
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
Serial.println("Serial connect OK");
Serial.println("Start Init...");
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue:
while (true);
char * buf = WiFi.firmwareVersion();
Serial.print("WIFI shield fireware version:");
Serial.println(buf);
// Print WiFi MAC address:
printMacAddress();
// scan for existing networks:
SearchWIFINetwork();
void printCurrentNet() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print the MAC address of the router you're attached to:
byte bssid[6];
WiFi.BSSID(bssid);
Serial.print("BSSID: ");
Serial.print(bssid[5], HEX);
Serial.print(":");
Serial.print(bssid[4], HEX);
Serial.print(":");
Serial.print(bssid[3], HEX);
Serial.print(":");
Serial.print(bssid[2], HEX);
Serial.print(":");
Serial.print(bssid[1], HEX);
Serial.print(":");
Serial.println(bssid[0], HEX);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.println(rssi);
// print the encryption type:
byte encryption = WiFi.encryptionType();
Serial.print("Encryption Type:");
Serial.println(encryption, HEX);
void printWifiData() {
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
byte mac[6];
Serial.print("MAC address: ");
Serial.print(":");
Serial.print(":");
Serial.print(":");
Serial.print(":");
Serial.print(":");
void connWIFI(char* aSSID,char* PSW )
if( WIFIstatus != WL_CONNECTED)
Serial.print("Attempting to connect to WPA SSID: ");
Serial.println(aSSID);
WIFIstatus = WiFi.begin(aSSID, PSW);
if (WIFIstatus==WL_CONNECTED)
Serial.println("Connected OK");
printCurrentNet();
printWifiData();
Udp.begin(1234);
Serial.print("Connected failed");
Serial.println("WIFI already connected.");
printCurrentNet();
printWifiData();
void DisConn()
if( WIFIstatus == WL_CONNECTED)
WiFi.disconnect();
WIFIstatus=WL_IDLE_STATUS;
Serial.print("WIFI Disconnect OK");
Serial.print("WIFI dose not connected");
void CharArrayCopy(char * src,char * dest, char length)
if (length>0)
for(char i=0;i<length;i++)
dest[i]=src[i];
void ClearSerialBuf()
Serial.flush();
lenOfBuf=0;
void WaitforInputAndRead()
while(lenOfBuf<=0)
ReadFromSerial();
delay(300);
void ReadFromSerial()
while(Serial.available()>0)
bufFromSerial[lenOfBuf++] = Serial.read();
if(lenOfBuf>0)
bufFromSerial[++lenOfBuf]='\0';
void JoininNewNetwork()
ClearSerialBuf();
Serial.print("Please Input the WIFI network name(SSID):");
WaitforInputAndRead();
if (lenOfBuf>0)
CharArrayCopy(bufFromSerial,tem1,lenOfBuf);
tem1Len=lenOfBuf;
Serial.println(bufFromSerial);
Serial.println("");
Serial.print("Invalid SSID name.");
return;
ClearSerialBuf();
Serial.print("Please Input the network password:");
if (lenOfBuf>0)
CharArrayCopy(bufFromSerial,tem2,lenOfBuf);
tem2Len=lenOfBuf;
Serial.println("");
Serial.print("Invalid password.");
return;
connWIFI(tem1,tem2);
void SetServerIP()
Serial.print("Current server address: ");
Serial.println(ServerIP);
ClearSerialBuf();
Serial.print("Please Input new ip address:");
if (lenOfBuf>0)
tem1Len=0;
tem2Len=0;
bufFromSerial[lenOfBuf-1]='.';
for(int i=0;i<lenOfBuf;i++)
if ((bufFromSerial[i]>='0') && (bufFromSerial[i]<='9'))
if(tem1Len<=2)
tem1[tem1Len++]=bufFromSerial[i];
Serial.println("Invalid IP address");
return;
if ((bufFromSerial[i]=='.'))
if(tem2Len<=3)
tem2[tem2Len]=0;
for(char j=0;j<tem1Len;j++)
tem2[tem2Len]+=((unsigned char)(tem1[j]-'0'))*pow(10,tem1Len-j-1);
if (tem1Len==3)
tem2[tem2Len]+=1;
tem2Len++;
tem1Len=0;
return;
return;
for(int i=0;i<4;i++)
ServerIP[i]=tem2[i];
Serial.println("Server updates OK");
Serial.print("New Server Ip is:");
void DisplayMenu()
while(true)
ClearSerialBuf();
Serial.println("");
Serial.println("**************************************************************************");
Serial.println("1.list all avaliable WIFI network.");
Serial.println("2.Join in a Network.");
Serial.println("3.Disconnect current network.");
Serial.println("4.Set Server IP Address.");
Serial.println("5.Send message to Server");
Serial.println("");
switch(bufFromSerial[0])
case '1':
case '2':
JoininNewNetwork();
case '3':
DisConn();
case '4':
SetServerIP();
case '5':
DisplayMenu();
!. if copy code and run ,the program would be repeat do :output some message and reboot
like this:
Serial connect OK
Start Init...
WIFI shield fireware version:1.0.0
MAC: 78:C4:E:2:18:A0
number of available networks:5
0) NETGEAR29 Signal: -28 dBm Encryption: WPA2
- EnGenius1 Signal: -33 dBm Encryption: WPA2
- Adherent Signal: -44 dBm Encryption: WPA2
- AP SERVER Signal: -45 dBm Encryption: WPA2
- belkin.e4c Signal: -75 dBm Encryption: WPA2
Attempting to connect to WPA SSID: NETGEAR29
Connected OK
SSIDª¥ ±connect OK
Start Init...
number of available networks:5 - NETGEAR29 Signal: -30 dBm Encryption: WPA2
- EnGenius1 Signal: -32 dBm Encryption: WPA2
- Adherent Signal: -42 dBm Encryption: WPA2
- AP SERVER Signal: -50 dBm Encryption: WPA2
- belkin.e4c Signal: -84 dBm Encryption: WPA2
Connected OK
SSIDª¥ ±connect OK
Start Init...
2.If you change all serial print message "OK" to "Successful"
The output would be like this:
Serial connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succ¥ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Succe³ª¥
±connect Successful
Start Init...
MAC:
3.if you delete the variable "UDP" in very beginning and in function connwifi, the program would be run correct.
I really don't understand why i change those would have those very strange impact for program.
hope someone could help me.
Thanks very much
