vfd control with arduino
Hello all
I would like to ask about how to control VFD with Arduino
VFD Type: Fuji Mini VFD
Data Sheet: https://www.fujielectric-europe.com/gallery/download/download_338/um_meh446.pdf
If I use the RS485 method what information will I need
Thank you
That is not an easy device.
They have a list of documents, have you read them all ?
  • FRENIC-Mini User's Manual (MEH446)
  • RS485 Communications User's Manual (MEH448)
  • Catalog (MEH441/MEH451)
  • Application Guide (MEH449)
  • RS485 Communications Card Installation Manual INR-SI47-0773
  • Rail Mounting Base Installation Manual INR-SI47-0774
  • Mounting Adapter Installation Manual INR-SI47-0775
  • PC Loader Operation Manual INR-SI47-0801-E
  • Remote Keypad Instruction Manual INR-SI47-0843-E
  • Built-in Braking Resistor Installation Manual INR-SI47-0838
You need a RS-485 board for the Arduino and connect that to a serial port.
The Arduino Leonardo has a spare serial port, also the Arduino Mega 2560 and the MKR boards with SAMD21G processor is also a good choice.
They have three protocols, the FGI-BUS seems the most simple protocol. I have never used Modbus, perhaps there are libraries to use that.
This video shows someone using the Modbus: Inverter Frenic mini interface Atmega16 RS485 Modbus RTU protocol 3 phase motor Speed control - YouTube.
The baudrate can be selected, the Arduino can do all of them.
The actual commands is not easy either. There can be many Frenic Mini stations on the RS-485 bus, you have to select the right device.
There is a command to request the diagnostics. If you start with that one, maybe you understand the rest.
Is there a program for a desktop computer ? Then you could buy a RS-485 to USB module and try that first.
Try to find examples, because it is not easy. I don't know if I could do it.
