Hello everyone,
I'm revisiting and upgrading an old circuit. Part of the upgrade is swapping out relays for low side mosfet switches/drivers:
Low-side MOSFET driver:
The load I'll be switching are small 12v, 100mA solenoid valves and a 12v 6W brushless motor on a pump.
Earlier this year, when learning about high-side/low-side switches, @larryd posted this overview schematic:
In it, it says that when using a logic level low side driver, the V_gs of the MOSFET needs to be >12V. In Nick Gammon's explanation on the matter, that need is not mentioned.
I don't understand where the restriction comes from: The source is always connected to GND (0V), the gate is either pulled low (0V) or sees logic high (5V) by the µC pin. That means, it will never be able to exceed a 5V delta, correct? Why the need for a Vgs_max of >12V then?
Im planning to use this IRLML6244 logic level N channel mosfet for the job, which has a Vgs_max of +/-12V. Should I reconsider?
While I'm at it (sanity check), for the high side swich connecting the VCC to the analog sensors and the SD card module I plan to use this IRLM2244. It works fine in my prototype, but as you can tell from the example above, I'm not 100% sure I know what I'm doing here.
Diodes
I'm planning on using 1N4148 diodes for compensating the inductive kickback of the solenoids and a 1N4007 for the motor switch. That should work fine in my opinion, or would anybody strongly recommend using a schottky diode instead?
Capacitiors
Do the 100n caps parallel to the valves make any sense, given they are powered by their own 12V supply? Or are those wasted?
Thanks in advance for your input!
