View multiple ESP32 CAM's on phone ?
Hi All.
I have an ESP32 CAM AI thinker working in softAP mode, so I can view video direct on my android phone in the Chrome browser, without any other WiFi hardware.
Any ideas to expand to 2 or even 3 cameras on the same screen ?
Any android apps ?
I could use 2nd and 3rd OLD smart phones, I guess.
Thank you
Trevor
Just open a 2nd and 3rd tab in the browser, you will need to assign different IP's of course but I see no issues.
Your phone can connect to only one WiFi at the same time. You need an access point where all devices can connect to.
Next you need an HTML page with 3 embedded video player. You can store it in one of the ESPs.
Thanks sonofcy,
But don't the cameras all have different SSID's ?
I'd rather not have to keep switching networks, between the different cameras.
Trevor
Can that be one of the cameras ?
What mode would the others be ?
Hmmmm .... I'll see what I can find out
Thank you
This subject seems to be solved here... Multiple ESP32 cams using one as a Soft Access point
I missed the part re SoftAP, you will need to use your router (or an esp32 or similar to act as router) and 'hang' each cam off that. Now one network for your phone to connect to and 3 IP's in 3 browser tabs.
Thanks sonofcy.
As I stated in the original post, I want to use the system without any other Wifi hardware, for a mobile wildlife application.
Thanks xfpd,
I did read that post, but it uses FTP to transfer files to a Raspberry PI.
I don't understand that.
I'm reading about having one CAM in AP mode and another in STA mode on the same SSID.
I'll try some tests
That's another solution or an extra esp32 or some smaller board for less power consumption.
SOLVED ! ....... (well for 2 cameras anyway)
Running one ESP32 CAM in AP mode and another in STA mode .... both on same SSID.
Then on android phone run chrome in split-screen mode, so 2 chromes on screen.
One window shows AP camera on 192.168.4.1, the other window shows STA camera on 192.168.4.4.
It works for now !!
Thanks for your help guys
Works even better on Chromebook Flip in tablet mode, with a much larger larger screen.
I only have 2 ESP32 CAM boards at the moment, but more coming soon to try more chrome windows on screen
