Hi, I'm trying to integrate the arduino language server, arduino/arduino-language-server, with vim/ale. I don't know very well how to use an LSP, but i managed, to some extent, to have some form of linting in the editor but lacks of any form of completion
This are the step to reproduce what i have:
- Install ale vim via plug
- install arduino-cli from repository (my version is 0.18.1-arch)
- clone the repository for arduino language server
- configure ale to use arduino language server (see below)
- i've also put the binaries and libraries for clangd, the indexing and the normal one, clangd/releases/tag/12.0.0 in the /usr/bin and /usr/lib
the configuration, in .vimrc:
let g:ale_completion_enabled = 1
let g:ale_completion_autoimport = 1
set omnifunc=ale#completion#OmniFunc
set completeopt=menu,menuone,popup,noselect,noinsert
let g:ale_linters = { 'cpp': ['clangd'] }
let g:ale_fixers = { 'cpp': [ 'clang-format' ] }
call ale#linter#Define('arduino', {
\ 'name': 'arduino_LSP',
\ 'lsp': 'stdio',
\ 'executable': 'MY_PATH/arduino-language-server/arduino-language-server',
\ 'command': '%e -board-name uno -cli-config $HOME/.arduino15/arduino-cli.yaml -log',
\ 'project_root': FindSessionDirectory(),
\ 'callback': {buffer, lines -> map(lines, '{"text": v:val, "lnum": 1}')},
In the log there is a lot of failure to start the arduino language server like:
2021/05/14 06:50:33 arduino-cli output: {
"compiler_out": "",
"compiler_err": "",
"builder_result": {
"build_path": "/tmp/arduino-language-server778687580"
"success": false
these are the log error:
inols-clangd-err.log
inols-err.log
here is the :ALEInfo result
Current Filetype: arduino
Available Linters: ['arduino_LSP']
Enabled Linters: ['arduino_LSP']
Ignored Linters: []
Suggested Fixers:
'remove_trailing_lines' - Remove all blank lines at the end of a file.
'trim_whitespace' - Remove all trailing whitespace characters at the end of every line.
Linter Variables:
Global Variables:
let g:ale_cache_executable_check_failures = v:null
let g:ale_change_sign_column_color = 0
let g:ale_command_wrapper = ''
let g:ale_completion_delay = 100
let g:ale_completion_max_suggestions = 50
let g:ale_disable_lsp = 0
let g:ale_echo_cursor = 1
let g:ale_echo_msg_error_str = 'Error'
let g:ale_echo_msg_format = '%code: %%s'
let g:ale_echo_msg_info_str = 'Info'
let g:ale_echo_msg_warning_str = 'Warning'
let g:ale_enabled = 1
let g:ale_fix_on_save = 0
let g:ale_fixers = {'cpp': ['clang-format']}
let g:ale_history_enabled = 1
let g:ale_history_log_output = 1
let g:ale_keep_list_window_open = 0
let g:ale_lint_delay = 200
let g:ale_lint_on_enter = 1
let g:ale_lint_on_filetype_changed = 1
let g:ale_lint_on_insert_leave = 1
let g:ale_lint_on_save = 1
let g:ale_lint_on_text_changed = 'normal'
let g:ale_linter_aliases = {}
let g:ale_linters = {'cpp': ['clangd']}
let g:ale_linters_explicit = 0
let g:ale_linters_ignore = {}
let g:ale_list_vertical = 0
let g:ale_list_window_size = 10
let g:ale_loclist_msg_format = '%code: %%s'
let g:ale_max_buffer_history_size = 20
let g:ale_max_signs = -1
let g:ale_maximum_file_size = v:null
let g:ale_open_list = 0
let g:ale_pattern_options = v:null
let g:ale_pattern_options_enabled = v:null
let g:ale_root = {}
let g:ale_set_balloons = 0
let g:ale_set_highlights = 1
let g:ale_set_loclist = 1
let g:ale_set_quickfix = 0
let g:ale_set_signs = 1
let g:ale_sign_column_always = 0
let g:ale_sign_error = '>>'
let g:ale_sign_info = '--'
let g:ale_sign_offset = 1000000
let g:ale_sign_style_error = '>>'
let g:ale_sign_style_warning = '--'
let g:ale_sign_warning = '--'
let g:ale_sign_highlight_linenrs = 0
let g:ale_statusline_format = v:null
let g:ale_type_map = {}
let g:ale_use_global_executables = v:null
let g:ale_virtualtext_cursor = 0
let g:ale_warn_about_trailing_blank_lines = 1
let g:ale_warn_about_trailing_whitespace = 1
Command History:
(executable check - success) /home/USER/clone/arduino-language-server/arduino-language-server
(started) ['/usr/bin/zsh', '-c', '''/home/USER/clone/arduino-language-server/arduino-language-server'' -board
-name uno -cli-config $HOME/.arduino15/arduino-cli.yaml -log']
how can i solve or debug this?
