Point taken.
(the ones i just found online seem to use voltage regulators as well).
Why you would say LINEAR regulators are
used in switching power supplies is beyond
my understanding. That make F**Kall sense !
"Am I to understand you are implying the use of linear monolithic voltage regulators
in buck converters because you happened to notice that they are "adjustable" and
somehow assumed that voltage adjustment capability implies the presence of one
or more linear monolithic voltage regulators , or am I misinterpreting your statement ?"
PS- In view of the fact that, technically speaking, almost every post eventually comes
down to an interrogation process, (I have seen posts run past 100 replies) , someone
has to play the "bad cop". Unfortunately we don't have a small room with a single chair
and a bright hanging overhead light... It might speed up the process.
If the OPs ALWAYS answered ALL the questions they are asked, then the correct name
for the process would be "Question/Answer" process. The whole reason interrogation is
used is because the person being question is avoiding the questions or simply not answering
at all. If you read all the posts , you will see that RARELY does an OP actually answer
all the questions. Instead, they completely ignore them and make a statement or ask
a different question. It is actually rare (strangely enough) that an OP will quote someone's
reply saying "I have no clue what this means" . It does happen, but it is the exception
rather than the norm. If there were AI software that locked the post until the OP answered
the questions, then none of this would be necessary and it would default to a simple
Question/Answer process and we could find out whatever we needed to know , knowing
we WILL get the answer. (keeping in mind that the OP MUST provide an answer or
simply state: "I don't know.", for every question asked, even if the resulting reply is:
Q1: "I don't know."
Q2: "I don't know."
Q3: "I don't know."
Q4: "I don't know."
Unfortunately, this is not the reality. Not even close. Human
nature is such that posters are afraid to appear like idiots, and so they ignore the questions
and ask something else, that is more on their level. Do you KNOW for a FACT that the
OP is aware that VOLTAGE REGULATION in a BUCK is the result of the switching of the
mosfet and the feedback from the output and the duty cycle is directly (or indirectly, depending
on how you look at) controlled by the output voltage ? No. You don't. To my point,
did the OP ask "HOW DOES A BUCK CONTROL THE OUTPUT VOLTAGE ?" No , he did not.
Did he ask any questions about the theory of operation of a buck converter or the fact
that some are fixed dc to dc converters (I have a 48Vdc to 5Vdc brick) while others are
adjustable ? No , he did not.
So if you ask someone questions and they avoid the questions or ignore them, and you
continue to ask questions, is that process not BY DEFINITION an INTERROGATION ?
in·ter·ro·gate
/inˈterəˌɡāt/
verb: interrogate; 3rd person present: interrogates; past tense: interrogated; past participle: interrogated; gerund or present participle: interrogating
ask questions of (someone, especially a suspect or a prisoner) closely, aggressively, or formally.
"ANSWER THE QUESTION !
DID YOU, OR DID YOU NOT MEASURE THE OUTPUT VOLTAGE ?"
