msg[0]=key; // load the array with your data, as many bytes as you need
vw_send((uint8_t *)msg, strlen(msg)); // send the character out
vw_wait_tx(); // Wait until the whole message is gone
Analog reads are 2 bytes (10 digits),
int analogValue = analogRead(A0); // returns a 16 bit number
which you have to split into 2.
byte lowerByte = (analogValue && 0x0F); // gives you the right hand 8 bits
byte upperByte = (analogValue >>8); // gives the left hand 8 bits
then for the transmit:
msg[0]= lowerByte
msg[1]= upperByte
on the other end, it back together
analogValue = upperByte<<8 + lowerByte;
#include <VirtualWire.h>
Serial.begin(9600); // Debugging only
Serial.println("setup");
// Initialise the IO and ISR
vw_set_ptt_inverted(true); // Required for DR3100
vw_setup(2000); // Bits per sec
vw_rx_start(); // Start the receiver PLL running
byte temp[VW_MAX_MESSAGE_LEN];
byte templen = VW_MAX_MESSAGE_LEN;
if (vw_get_message(temp, &templen)) // Non-blocking
int i,lowerByte,upperByte,tempread;
digitalWrite(13, true); // Flash a light to show received good message
// Message with a good checksum received, dump it.
temp[0]= lowerByte;
temp[1]= upperByte;
tempread= upperByte<<8 + lowerByte;
Serial.print("Got: ");
for (i = 0; i < templen; i++)
Serial.print(temp[i], BYTE);
Serial.print(" ");
Serial.println("");
Serial.println(tempread);
digitalWrite(13, false);
Tx
char temp[2];
int tempread=analogRead(A0);
byte lowerByte = (tempread && 0x0F); // gives you the right hand 8 bits
byte upperByte = (tempread); // gives the left hand 8 bits
vw_send((uint8_t *)temp, strlen(temp));
delay(200);
It gets compiled perfectly,but never comes in working.
I cant receive anything.
unless you have a transmitter that actually needs that, most of the simple 433 MHz types don't.
Tx, you have to put the data into the array:
char temp[2];
// put the temperature bytes into the array for sending:
temp[0] = (tempread && 0x0F); // gives you the right hand 8 bits
temp[1] = (tempread>> 8 ); // gives the left hand 8 bits
vw_send((byte *) &tempread, sizeof (tempread));
Anyway, all this mucking around with copying bytes hither and thither makes me nervous. How about a union?
I'll illustrate with the Wire library as I don't have the VirtualWire installed:
#include <Wire.h>
// union of int and bytes
typedef union
int i;
byte c [2];
} t_int;
void setup ()
Wire.begin ();
void loop ()
// make a union variable
t_int reading;
// get the reading
reading.i = analogRead (0);
// send it
Wire.send (reading.c, sizeof reading.c);
The union lets you look at a variable in two ways - one way is an int (for the analogRead) and the other way is two bytes (for sending).
char temp[2];
temp[0] = tempread & 0x0F; // gives you the low-order bits
temp[1] = tempread >> 8 ; // gives the high-order bits
The low-order byte goes into the first byte of temp, and if the high-order bits are zero you are lucky. It will send one byte. This is because strlen calculates how many bytes there are, until it hits a zero.
But if the reading was, say 0x114 (decimal 276) then you will have to hope that there is a zero beyond temp. If not, strlen (temp) might be 100 or something.
However you really should use sizeof (temp) because you have two bytes you want to send, and sizeof (temp) is 2, regardless of the contents.
Maybe your remote control shield uses different code to the above, that might explain why it works.
I am puzzled by this. I don't have the VirtualWire library, and you haven't told me where to find it. But why pass the address of the length?
And just run by me what this is doing ...
temp[0]= lowerByte;
temp[1]= upperByte;
tempread= (upperByte<<8) + lowerByte;
I am guessing that vw_get_message reads into "temp". Then you discard temp by replacing both bytes with bytes that are undefined. Then you combine those into tempread.
I am not ignoring the concept of union,but I could not understand the concept.
See,I am getting thing over air now.
but In both ends,the splitting to msb and lsb and the reconstruction are the problem.
I think the problem is with the splitting,which will make everything else error prone.
well, this is where i stand.
TX
char temp[2];
int tempread= 101;
Serial.println("_________________________");
Serial.println(tempread,BIN);
Serial.println("................................");
byte lowerByte = (tempread & 000000001111111); // gives you the right hand 8 bits
byte upperByte = (tempread<< 8 ); // gives the left hand 8 bits
Serial.println(lowerByte,BIN);
Serial.println("L");
Serial.println(upperByte,BIN);
Serial.println("U");
temp[0]=lowerByte;
temp[1]=upperByte;
vw_send((uint8_t *)temp, sizeof(temp));
delay(200);
RX
int i,tempread;
byte lowerByte,upperByte;
Serial.println(temp[i],BIN);
Serial.println("");
Serial.println(VW_MAX_MESSAGE_LEN);
tempread = (temp[0] << 8 ) | temp[1];
