Hello,
Trying to build a vlc system for a project was able to tx and rx but am trying to blink the led from the tx and then use a photodiode to transmit those blinks as 1s and 0s to form an ASCII transition.
please any help with codes???
Hello,
We can't see your code.
Didn't write any cause am very new to arduino
We can't see your schematic either.
Or your specifications.
Can you see our difficulty?
tsiproGH:
Ah, but the way to learn is to do.
Do you have an arduino? And an LED with a current limiting resistor?
You can code the blink tutorial to get started.
Then start by reading some tutorials on Arduino. Or if you don't know C programming, start with that and then go for Arduino.
That said, I wonder how much range you can get in visible light using an LED (which is pretty dim compared to normal ambient light) and a photo diode (which is commonly used for IR rather than visible). My estimate is a few mm in normal light and a maybe a few cm in the dark.
wvmarle:
Then start by reading some tutorials on Arduino. Or if you don't know C programming, start with that and then go for Arduino.That said, I wonder how much range you can get in visible light using an LED (which is pretty dim compared to normal ambient light) and a photo diode (which is commonly used for IR rather than visible). My estimate is a few mm in normal light and a maybe a few cm in the dark.
I once built an analogue visible (red) light communication device using little more than a couple of 741 op-amps. With a simple lens system (a couple of solder tubes with cheap plastic lenses and toilet-roll lens hoods) range was easily 10 or 15 metres (the distance from my bedroom to my dad's garden shed), even in what passes for daylight in West Lancashire.
Read here
LiFi Emitter and Receiver
The purpose of this demos is to demonstrate data communication using a pair of blue LED (one led as emitter one led as receiver).
Communication can go at up to 600bs (can depend on led quality)
Hardware is the following :
I/O D2 ------[resistor]----- led -------------- GND
Using a blue led should not require resistor, one may be needed for red or green
A byte is sent as follow :
Start(0) 8bit data Stop(1)
Each bit is coded in manchester with
0 -> 10
1 -> 01
A data frame is formatted as follow :
0xAA : sent a number of time to help the received compute a signal average for the thresholding of analog values
0xD5 : synchronization byte to break preamble
0x02 : STX start of frame
N times Effective data excluding command symbols, with N < 32
0x03 : ETX end of frame
#include <TimerOne.h>
#include <util/atomic.h>
//Start of what should be an include ...
//#define TRANSMIT_SERIAL
// change to alter communication speed,
// will lower values will result in faster communication
// the receiver must be tuned to the same value
#define SYMBOL_PERIOD 500 /* Defined a symbol period in us*/
#define WORD_LENGTH 10 /* Each byte is encoded on 10-bit with start, byte, stop */
#define SYNC_SYMBOL 0xD5 /* Synchronization symbol to send after a preamble, before data communication happens */
#define ETX 0x03
#define STX 0x02
//Fast manipulation of LED IO.
//These defines are for a LED connected on D13
/*#define OUT_LED() DDRB |= (1 << 5);
#define SET_LED() PORTB |= (1 << 5)
#define CLR_LED() PORTB &= ~(1 << 5)
//These defines are for a RGB led connected to D2, D3, D4
/*#define OUT_LED() DDRD |= ((1 << 2) | (1 << 3) | (1 << 4))
#define SET_LED() PORTD |= ((1 << 2) | (1 << 3) | (1 << 4))
#define CLR_LED() PORTD &= ~((1 << 2) | (1 << 3) | (1 << 4))
//These defines are for a single led connected to D2
#define OUT_LED() DDRD |= ((1 << 2))
#define SET_LED() PORTD |= ((1 << 2))
#define CLR_LED() PORTD &= ~((1 << 2))
unsigned char frame_buffer [38] ; //buffer for frame
char frame_index = -1; // index in frame
char frame_size = -1 ; // size of the frame to be sent
//state variables of the manchester encoder
unsigned char bit_counter = 0 ;
unsigned short data_word = 0 ; //8bit data + start + stop
unsigned char half_bit = 0 ;
unsigned long int manchester_data ;
void to_manchester(unsigned char data, unsigned long int * data_manchester){
unsigned int i ;
(*data_manchester) = 0x02 ; // STOP symbol
(*data_manchester) = (*data_manchester) << 2 ;
for(i = 0 ; i < 8; i ++){
if(data & 0x80) (*data_manchester) |= 0x02 ; // data LSB first
else (*data_manchester) |= 0x01 ;
data = data << 1 ; // to next bit
(*data_manchester) |= 0x01 ; //START symbol
//emitter interrupt
void emit_half_bit(){
if(manchester_data & 0x01){
SET_LED();
}else{
CLR_LED();
bit_counter -- ;
manchester_data = (manchester_data >> 1);
if(bit_counter == 0){
//is there still bytes to send in the frame ?
manchester_data = 0xAAAAAAAA ; // keep sending ones if nothing to send
if(frame_index >= 0 ){
if(frame_index < frame_size){
/*Serial.println(frame_index, DEC);
Serial.println(frame_buffer[frame_index], HEX);*/
to_manchester(frame_buffer[frame_index], &manchester_data);
frame_index ++ ;
}else{
frame_index = -1 ;
frame_size = -1 ;
bit_counter = WORD_LENGTH * 2 ;
//Serial.println(manchester_data, BIN);
void init_frame(unsigned char * frame){
memset(frame, 0xAA, 3);
frame[3] = SYNC_SYMBOL ;
frame[4] = STX;
frame_index = -1 ;
frame_size = -1 ;
int create_frame(char * data, int data_size, unsigned char * frame){
memcpy(&(frame[5]), data, data_size);
frame[5+data_size] = ETX;
return 1 ;
int write(char * data, int data_size){
if(frame_index >= 0) return -1 ;
if(data_size > 32) return -1 ;
create_frame(data, data_size,frame_buffer);
ATOMIC_BLOCK(ATOMIC_RESTORESTATE){
frame_index = 0 ;
frame_size = data_size + 6 ;
return 0 ;
int transmitter_available(){
if(frame_index >= 0) return 0 ;
return 1 ;
void init_emitter(){
manchester_data = 0xFFFFFFFF ;
// the setup routine runs once when you press reset:
// initialize serial communication at 115200 bits per second:
OUT_LED();
init_frame(frame_buffer);
init_emitter();
Timer1.initialize(SYMBOL_PERIOD); //1200 bauds
Timer1.attachInterrupt(emit_half_bit);
// the loop routine runs over and over again forever:
char * msg = "Hello World" ;
char com_buffer [32] ;
char com_buffer_nb_bytes = 0 ;
#ifdef TRANSMIT_SERIAL
if(Serial.available() && transmitter_available()){ //constructing the data frame only if transmitter is ready to transmit
char c = Serial.read();
com_buffer[com_buffer_nb_bytes] = c ;
com_buffer_nb_bytes ++ ;
if(com_buffer_nb_bytes >= 32 || c == '\n'){
if(write(com_buffer, com_buffer_nb_bytes) < 0){
Serial.println("Transmitter is busy");
}else{
delay(10);
#else
static int i = 0 ;
memcpy(com_buffer, msg, 11);
com_buffer[11] = i + '0' ;
if(write(com_buffer, 12) < 0){
delay(10);
}else{
i ++ ;
if(i > 9) i = 0 ;
#endif
AWOL:
Impressive! That must have been some pretty faint signals you were detecting, and a very well done focussing.
for the Tx we have an LED sending 0s and 1s through its blink ON and OFF while
Rx with a sensor(photodiode) upon sensing this blinks convert them to 0s and 1s and then back to the characters sent from the Tx.
the block diagram is below
@tsiproGH, do not cross-post. Other thread removed.
