Visualizing bits in a register
The page https://docs.arduino.cc/learn/programming/bit-math/ gives below example for setting pins using registers, supposedly much faster than using a loop and pinMode and digitalWrite. Is there an easy way to print each bit for these ports in loop()?? Thanks for any help. AA
  DDRD = B11111110;  // digital pins 7,6,5,4,3,2,1,0
  PORTD &= B00000011;   // turns off 2..7, but leaves pins 0 and 1 alone
  DDRB = B00111111;  // digital pins -,-,13,12,11,10,9,8
  PORTB = B00111000;   // turns on 13,12,11; turns off 10,9,8
    for (int b = 7; b >= 0; b--)
        Serial.print(bitRead(DDRD, b));
You could just use
Serial.println(DDRD, BIN);
but leading zeroes will not be printed
Official page introduction to ports here.
https://docs.arduino.cc/retired/hacking/software/PortManipulation/
If you want to see the change in PORT value
DDRD = DDRD | B11111100;
PORTD = B10100000;
Serial.println("Binary");
Serial.println(PORTD,BIN);
Serial.println("Decimal");
Serial.println(PORTD,DEC);
delay(5000);
PORTD += 4;
