VL53L0X sensor, serial data to be displayed on web Page
I'm working on a project using two Vl53l0x sensors and an arduino uno. I have the distance sensors giving me the readings on the serial monitor but my challenge now is to get these readings being displayed on a webpage. I also understand how to display analog I/o pins on a webpage but I'm having a big problem trying to combine the two codes. I have attached my code below. Any help will be highly appreciated. Again my sensor is giving me the readings I need. Also I'm able to display a test code on a webpage using my local ip address. My problem is combining this two codes together to get my outputs on a webpage. I have tried different things but unable to get it to work.
#include "Adafruit_VL53L0X.h"
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
IPAddress ip(10, 0, 0, 4);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
#define VL53L0X_L0X1_I2C_ADDR  0x30
#define VL53L0X_L0X2_I2C_ADDR  0x31
Adafruit_VL53L0X L0X1 = Adafruit_VL53L0X();
Adafruit_VL53L0X L0X2 = Adafruit_VL53L0X();
const byte L1RangeFinderShutdownOutputPin = 8;
const byte L2RangeFinderShutdownOutputPin = 9;
Ethernet.begin(mac, ip);
  server.begin();
  Serial.print("server is at ");
  Serial.println(Ethernet.localIP());
  pinMode (L1RangeFinderShutdownOutputPin, OUTPUT);
  pinMode (L2RangeFinderShutdownOutputPin, OUTPUT);
  // wait until serial port opens for native USB devices
  while (! Serial) {
    delay(1);
  digitalWrite (L1RangeFinderShutdownOutputPin,1);
  digitalWrite (L2RangeFinderShutdownOutputPin,0);
  Serial.println(F("Adafruit VL53L0X L0X1 test"));
  if (!L0X1.begin()) {
    Serial.println(F("Failed to boot VL53L0X L0X1"));
    while(1);
  L0X1.setAddress(VL53L0X_L0X1_I2C_ADDR);
  digitalWrite (L2RangeFinderShutdownOutputPin,1);
  Serial.println("Adafruit VL53L0X L0X2 test");
  if (!L0X2.begin()) {
    Serial.println(F("Failed to boot VL53L0X L0X2"));
    while(1);
  L0X2.setAddress(VL53L0X_L0X2_I2C_ADDR);
  // power
  Serial.println(F("VL53L0X API Simple Ranging example\n\n"));
  if (client) {
    Serial.println("new client");
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial.write(c);
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          client.println("Content-Type: text/html");
          client.println("Connection: close");  // the connection will be closed after completion of the response
          client.println("Refresh: 5");  // refresh the page automatically every 5 sec
          client.println();
          client.println("<!DOCTYPE HTML>");
          client.println("<html>");
VL53L0X_RangingMeasurementData_t L0X1measure;
  VL53L0X_RangingMeasurementData_t L0X2measure;
  client.print(F("Reading measurementsfrom L0X1 ... "));
  L0X1.rangingTest(&L0X1measure, false); // pass in 'true' to get debug data printout!
  if (L0X1measure.RangeStatus != 4) {  // phase failures have incorrect data
    client.print(F("Distance (mm): ")); client.println(L0X1measure.RangeMilliMeter);
    client.println(F(" out of range "));
  client.print(F("Reading measurementsfrom L0X2 ... "));
  L0X2.rangingTest(&L0X2measure, false); // pass in 'true' to get debug data printout!
  if (L0X2measure.RangeStatus != 4) {  // phase failures have incorrect data
    client.print(F("Distance (mm): ")); client.println(L0X2measure.RangeMilliMeter);
  int delta = (L0X1measure.RangeMilliMeter-L0X2measure.RangeMilliMeter);
  client.print(F("Distance (mm): ")); client.println(delta);
          client.println("</html>");
        if (c == '\n') {
          // you're starting a new line
        } else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
 client.stop();
    Serial.println("client disconnected");
} [code]
[/code]
