VNH2SP30 and CS pin problems
Hi, I am working on a project that uses DC motors, and I need some kind of "fail-safe" condition in my code. I was planning to use CS pin on my VNH2SP30 controller, but readings I get make no sense. I connected CS PIN to A2 of my Arduino Uno. When I start serial monitoring, values frpm A2 pin start at ~700, then it stabilizes at ~360. The problem is values stay at 360 all the time, even if I lock the motor with my hand so it can't spin.
Here is my code:
#define BRAKE 0
#define CW    1
#define CCW   2
//MOTOR 1
#define MOTOR_A1_PIN 11  //INA
#define MOTOR_B1_PIN 10 //INB
#define PWM_MOTOR_1 9    //PWM
#define CURRENT_SEN_1 A2  //CS
#define EN_PIN_1 A0   //EN
#define MOTOR_1 0
#define CS_THRESHOLD 15
const int buttonPin = 4;     // the number of the pushbutton pin
const int buttonPin1 = 3;
int buttonState = LOW;         // variable for reading the pushbutton status
int buttonState1 = LOW;
pinMode(buttonPin, INPUT);
pinMode(buttonPin1, INPUT);
  pinMode(MOTOR_A1_PIN, OUTPUT);
  pinMode(MOTOR_B1_PIN, OUTPUT);
  pinMode(PWM_MOTOR_1, OUTPUT);
  pinMode(CURRENT_SEN_1, INPUT);
  pinMode(EN_PIN_1, OUTPUT);
  buttonState = digitalRead(buttonPin);
  buttonState1 = digitalRead(buttonPin1);
   if (buttonState == HIGH)
      digitalWrite(EN_PIN_1, HIGH);
      digitalWrite(MOTOR_A1_PIN, LOW);
      digitalWrite(MOTOR_B1_PIN, HIGH);
      analogWrite(PWM_MOTOR_1, 50);
      delay(100);
       if (analogRead(CURRENT_SEN_1) > CS_THRESHOLD)
      Serial.println(analogRead(CURRENT_SEN_1));
  else if (buttonState1 == HIGH)
      digitalWrite(MOTOR_A1_PIN, HIGH);
      digitalWrite(MOTOR_B1_PIN, LOW);
      analogWrite(PWM_MOTOR_1, 130);
      delay(100);
  else if (buttonState == LOW and buttonState1 == LOW)
      digitalWrite(MOTOR_A1_PIN, LOW);            //triba li ovde pwm??
  else if (buttonState == HIGH and buttonState1 == HIGH)
logical error.
+> the last test will never happen
What analog filtering do you have on the CS pin? The basic Arduino PWM is so slow that your analogRead() will randomly see peak current or zero current and you have no idea what the average current is.
Here's my circuit to average out the PWM peaks and get a reasonable current reading from a VNH2SP30:
