Voice control car using hc-05 problem got problem
here i have assembled 4 dc motors , arduino uno , L293d motor driver , hc-05 bluetooth module and the progrom(sketch ) and also displays upload success. but its not working why? help me here
sketch code from here
Arduino Bluetooth Controlled Car
Install Adafruit Motor Shield Library before uploading this code.
AFMotor Library Library Install | Adafruit Motor Shield | Adafruit Learning System
-> If you need helping guide on how to install library for the motor shield or how to use motor shield then
watch this: https://youtu.be/vooJEyco1J4
 Caution: Remove the jumper or switch off the battery switch before connecting the Arduino board to computer.
 For more support contact me on Telegram: @UtGoTech
#include <AFMotor.h>
#include <SoftwareSerial.h>
SoftwareSerial bluetoothSerial(9, 10); // RX, TX
//initial motors pin
AF_DCMotor motor1(1, MOTOR12_1KHZ);
AF_DCMotor motor2(2, MOTOR12_1KHZ);
AF_DCMotor motor3(3, MOTOR34_1KHZ);
AF_DCMotor motor4(4, MOTOR34_1KHZ);
char command;
bluetoothSerial.begin(38400); //Set the baud rate to your Bluetooth module.
if (bluetoothSerial.available() > 0) {
command = bluetoothSerial.read();
Stop(); //initialize with motors stoped
switch (command) {
  case 'F':
    forward();
  case 'B':
    back();
  case 'L':
    left();
  case 'R':
    right();
void forward()
motor1.setSpeed(255); //Define maximum velocity
motor1.run(FORWARD); //rotate the motor clockwise
motor2.setSpeed(255); //Define maximum velocity
motor2.run(FORWARD); //rotate the motor clockwise
motor3.setSpeed(255); //Define maximum velocity
motor3.run(FORWARD); //rotate the motor clockwise
motor4.setSpeed(255); //Define maximum velocity
motor4.run(FORWARD); //rotate the motor clockwise
void back()
motor1.run(BACKWARD); //rotate the motor anti-clockwise
motor2.run(BACKWARD); //rotate the motor anti-clockwise
motor3.run(BACKWARD); //rotate the motor anti-clockwise
motor4.run(BACKWARD); //rotate the motor anti-clockwise
void left()
void right()
void Stop()
motor1.setSpeed(0); //Define minimum velocity
motor1.run(RELEASE); //stop the motor when release the button
motor2.setSpeed(0); //Define minimum velocity
motor2.run(RELEASE); //rotate the motor clockwise
motor3.setSpeed(0); //Define minimum velocity
motor3.run(RELEASE); //stop the motor when release the button
motor4.setSpeed(0); //Define minimum velocity
motor4.run(RELEASE); //stop the motor when release the button
#####code ends here
IMG_20241203_083316|225x500
Code required to be in code tags.
Include a circuit diagram showing all connections including power supplies ( Not fritzing) and all terminal pin numbers.
Your power supply is not sufficient.
