Void Loop function to change and stay in next loop
Im trying to get the below to change to a separate Void function but using the buttons and have the loop stay until the button is pressed, idea behind this is so i can change the display to a different loop function.
The below works in as much as i can select the sketch i want, but it seems to block the loop and i have to cycle through the buttons...
Main sketch
#include <Arduino.h>
#define LILYGO_T5_V213
#include "boards.h"
int buttonPin1 = 39;
int buttonPin2 = 38;
int buttonPin3 = 37;
  pinMode(buttonPin1, INPUT_PULLUP);
  pinMode(buttonPin2, INPUT_PULLUP);
  pinMode(buttonPin3, INPUT_PULLUP);
  while (digitalRead(buttonPin1) == HIGH) {
    Screen1();
  while (digitalRead(buttonPin2) == HIGH) {
    Screen2();
  while (digitalRead(buttonPin3) == HIGH) {
    Screen3();
Sketch example
void Screen1(){
Serial.println("Screen 1");
and the question is?
Don't use while but use if.
as this
do one step after the other:
loop
  • read a button
  • if a button is pressed, change the value of a variable like byte lastPressedButton
  • show the menu based on the current value of lastPressedButton
i managed to get it to work this way ,, but im certain this is not very clean
#include "boards.h"
int buttonPin1 = 37;
int buttonPin3 = 39;
  pinMode(buttonPin1, INPUT);
  pinMode(buttonPin2, INPUT);
  pinMode(buttonPin3, INPUT);
  if (digitalRead(buttonPin1) == LOW) {
    Screen1();
  if (digitalRead(buttonPin2) == LOW) {
    Screen2();
  if (digitalRead(buttonPin3) == LOW) {
    Screen3();
2nd part
void Screen1() {
    Screen2();
    Screen3();
  Screen1();
Never call a function from within the same function (directly or indirectly). It's called recusrion and you will run out of memory in no time.
Something like this does not suffer from recursion.
#include "boards.h"
// indicates the active screen
int activeScreen = 1;
    activeScreen = 1;
    activeScreen = 2;
    activeScreen = 3;
  switch(activeScreen)
    case 1:
      Screen1();
    case 2:
      Screen2();
    case 3:
      Screen3();
void Screen1()
  Serial.println("screen1");
void Screen2()
  Serial.println("screen2");
void Screen3()
  Serial.println("screen3");
In ScreenX, do not use blocking code.
You might want to give more details of your project for better advise.
Wow thank you for taking the time to code that information.
I'm making a small flying screen for my Paramotor with different screens that I can switch between .
